跳转到主内容
加入维修社区 - 创建账户
Nokero N400 Switch Replacement
你所需要的
  1. Nokero N400 Switch Replacement, Remove Battery Cover: 步骤 1 中的图像 1,3 Nokero N400 Switch Replacement, Remove Battery Cover: 步骤 1 中的图像 2,3 Nokero N400 Switch Replacement, Remove Battery Cover: 步骤 1 中的图像 3,3
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 Switch Replacement, Unscrew Back Cover: 步骤 2 中的图像 1,2 Nokero N400 Switch Replacement, Unscrew Back Cover: 步骤 2 中的图像 2,2
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 Switch Replacement, Pry Open Back Cover: 步骤 3 中的图像 1,2 Nokero N400 Switch Replacement, Pry Open Back Cover: 步骤 3 中的图像 2,2
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 Switch Replacement, Remove Switch From Housing: 步骤 4 中的图像 1,1
    • Using a spudger carefully pry switch from housing.
  5. Nokero N400 Switch Replacement, Cut Old Switch Free: 步骤 5 中的图像 1,1
    • Use wire cutters to cut the two black wires attached to the old switch.
    • You must use a splicer or a soldering gun to reattach the wires of the new switch.
    • If you splice the new switch wires together in the opposite order of the old switch wires, the new switch will still work.
结论
Benjamin franklin
于01/20/15注册
101 声望
撰写一个指南
团队
USF Tampa, Team 19-2, Blackwell Winter 2015 USF Tampa, Team 19-2, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S19G2
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 21
总计 276
