跳转到主内容
Nokero N400 Solar Panel Replacement
你所需要的
  1. Nokero N400 Solar Panel Replacement, Remove Battery Cover: 步骤 1 中的图像 1,3 Nokero N400 Solar Panel Replacement, Remove Battery Cover: 步骤 1 中的图像 2,3 Nokero N400 Solar Panel Replacement, Remove Battery Cover: 步骤 1 中的图像 3,3
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 Solar Panel Replacement, Unscrew Back Cover: 步骤 2 中的图像 1,2 Nokero N400 Solar Panel Replacement, Unscrew Back Cover: 步骤 2 中的图像 2,2
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 Solar Panel Replacement, Pry Open Back Cover: 步骤 3 中的图像 1,2 Nokero N400 Solar Panel Replacement, Pry Open Back Cover: 步骤 3 中的图像 2,2
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 Solar Panel Replacement, Solar Panel: 步骤 4 中的图像 1,2 Nokero N400 Solar Panel Replacement, Solar Panel: 步骤 4 中的图像 2,2
    • Pull the panel away from the rest of the assembly and cut the red and black wires coming from the panel
    • Be careful not to cut the ground-wire for the motherboard, it is the same color and goes to the exact same place as the solar panel wire.
    • For reassembly you will need to either splice, or solder the wires onto the replacement.
结论
Daniel Bumiller
于01/20/15注册
201 声望
创作了2篇指南
团队
USF Tampa, Team 19-2, Blackwell Winter 2015 USF Tampa, Team 19-2, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S19G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 161
