跳转到主内容
加入维修社区 - 创建账户
Nokero N400 LED Panel Replacement
你所需要的
  1. Nokero N400 LED Panel Replacement, Remove Battery Cover: 步骤 1 中的图像 1,3 Nokero N400 LED Panel Replacement, Remove Battery Cover: 步骤 1 中的图像 2,3 Nokero N400 LED Panel Replacement, Remove Battery Cover: 步骤 1 中的图像 3,3
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 LED Panel Replacement, Unscrew Back Cover: 步骤 2 中的图像 1,2 Nokero N400 LED Panel Replacement, Unscrew Back Cover: 步骤 2 中的图像 2,2
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 LED Panel Replacement, Pry Open Back Cover: 步骤 3 中的图像 1,2 Nokero N400 LED Panel Replacement, Pry Open Back Cover: 步骤 3 中的图像 2,2
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 LED Panel Replacement, Removing the LED Panel: 步骤 4 中的图像 1,2 Nokero N400 LED Panel Replacement, Removing the LED Panel: 步骤 4 中的图像 2,2
    • With the back cover of the device removed, lightly pull up on the LED assembly to lift it out of its housing.
    • The LED assembly will separate into three components; the light board, outer housing, and plastic lens.
  5. Nokero N400 LED Panel Replacement: 步骤 5 中的图像 1,1
    • Set the outer housing and plastic lens aside.
    • Take a pair of pliers and cut the red and black wires connected to the light board.
    • Make sure to cut just below the light board.
    • To install the new light board, you will need to splice or solder the wires to the new light board.
结论
另外一个人完成了本指南。
Kyle Burwell
于01/20/15注册
173 声望
撰写一个指南
团队
USF Tampa, Team 19-2, Blackwell Winter 2015 USF Tampa, Team 19-2, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S19G2
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 348
