跳转到主内容
Nokero N222-Huron Mounting Technique
你所需要的
  1. Nokero N222-Huron Mounting Technique, Nokero N222-Huron Mounting Technique: 步骤 1 中的图像 1,1
    • Place the mounting bracket in the desired location and mark the center location. This is where the screw will be placed.
    • It is optional to drill a pilot hole for the screw if splitting is a concern (usually for mounting in wood).
  2. Nokero N222-Huron Mounting Technique: 步骤 2 中的图像 1,3 Nokero N222-Huron Mounting Technique: 步骤 2 中的图像 2,3 Nokero N222-Huron Mounting Technique: 步骤 2 中的图像 3,3
    • Place the screw through the bracket, as shown, and screw it into the marked or drilled location.
  3. Nokero N222-Huron Mounting Technique: 步骤 3 中的图像 1,1
    • Make sure the bracket is facing in the desired direction before tightening the screw.
    • When the Nokero logo is facing forward, the light will pivot forward and backward.
  4. Nokero N222-Huron Mounting Technique: 步骤 4 中的图像 1,3 Nokero N222-Huron Mounting Technique: 步骤 4 中的图像 2,3 Nokero N222-Huron Mounting Technique: 步骤 4 中的图像 3,3
    • Place the light in the bracket as shown and turn clockwise until it is secure.
结论
To remove or change the fixed mount for your device, follow these instructions in reverse order.
Vinny Capone
于10/18/13注册
549 声望
创作了5篇指南
团队
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2013 UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2013 的会员
UMASSD-GULBRANDSEN-F13S2G4
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 202
