跳转到主内容
Nokero N222-Huron Colored Lens Replacement
  1. Nokero N222-Huron Colored Lens Replacement, Clear Cover: 步骤 1 中的图像 1,1
    • Grasp the clear cover and the white housing and twist the cover counter-clockwise.
    • The lid may hold fast, but it will come off with some firm twisting.
  2. Nokero N222-Huron Colored Lens Replacement: 步骤 2 中的图像 1,1
    • Lift the lid from the device
    • It may be helpful to use a spudger to pry under the lid if there is difficulty in getting a good grip on the smooth plastic.
  3. Nokero N222-Huron Colored Lens Replacement, Colored Lens: 步骤 3 中的图像 1,3 Nokero N222-Huron Colored Lens Replacement, Colored Lens: 步骤 3 中的图像 2,3 Nokero N222-Huron Colored Lens Replacement, Colored Lens: 步骤 3 中的图像 3,3
    • Turn the lens until the slots line up with the retaining clips on the device.
    • Lift the lens off of the device. It should come off easily.
  4. Nokero N222-Huron Colored Lens Replacement: 步骤 4 中的图像 1,2 Nokero N222-Huron Colored Lens Replacement: 步骤 4 中的图像 2,2
    • When reinstalling the lends, line up the slots of the new lens with the retaining clips, and rotate the lens counter-clockwise.
    • You will hear an audible click when the lens is locked in place.
结论
To reassemble your device, follow the instructions for the first two steps in reverse order.
Vinny Capone
于10/18/13注册
549 声望
创作了5篇指南
团队
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2013 UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2013 的会员
UMASSD-GULBRANDSEN-F13S2G4
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 13
总计 246
