跳转到主内容
Noisy Percussion Massager Repair
你所需要的
  1. Noisy Percussion Massager Repair, Tools - #1 & #2 Phillips + thread locker: 步骤 1 中的图像 1,1
    • Thread lock can be found at any hardware store.
  2. Noisy Percussion Massager Repair, Remove the rear cover: 步骤 2 中的图像 1,2 Noisy Percussion Massager Repair, Remove the rear cover: 步骤 2 中的图像 2,2
    • Twist counter-clockwise very snug. It only moves about 1/4 of an inch - the second picture shows the slide lock slots.
  3. Noisy Percussion Massager Repair, Remove Two Screws from Housing: 步骤 3 中的图像 1,1
    • There were actually two rubber plugs covering the screws that I had to work out… Not hard.
  4. Noisy Percussion Massager Repair, Open It Up: 步骤 4 中的图像 1,3 Noisy Percussion Massager Repair, Open It Up: 步骤 4 中的图像 2,3 Noisy Percussion Massager Repair, Open It Up: 步骤 4 中的图像 3,3
    • Case opens pretty easy but you can see there are two tabs toward the back of the case … if it sticks, a simple pinch might help you open it up.
  5. Noisy Percussion Massager Repair, Remove screw - Apply Thread Lock - Re install: 步骤 5 中的图像 1,3 Noisy Percussion Massager Repair, Remove screw - Apply Thread Lock - Re install: 步骤 5 中的图像 2,3 Noisy Percussion Massager Repair, Remove screw - Apply Thread Lock - Re install: 步骤 5 中的图像 3,3
    • Insert wisdom here.
  6. Noisy Percussion Massager Repair, Re-assemble the case: 步骤 6 中的图像 1,2 Noisy Percussion Massager Repair, Re-assemble the case: 步骤 6 中的图像 2,2
    • Surprising how much noise a loose screw can cause.
结论
另外一个人完成了本指南。
jtalbin
于07/22/12注册
313 声望
创作了2篇指南
8条评论
Where can I buy a gasket, for the Recovery Pro massager, that is worn out? Thank you.
Emilia Cirstea - 回复
We were unable to twist off the back on Step 2. Going to be returned to Costco since I can't fix it....
Richard DalCanto - 回复
I have model 11mg0811 it has no screws on the sides and I it will not twist off ,when it's on it makes a lot of noise,I don't want to return it to COSTCO IS THERE SOMEWHERE I CAN TAKE IT,
Ted - 回复
I've not found any shops locally that take these for repair. After looking at the pictures for the model 11MG0811 it appears that access to the inner workings is similar to an electronic toothbrush that uses a pinch/lock approach which can be quite a bit tougher.
jtalbin -
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 32
过去 30 天: 185
总计 9,856
