跳转到主内容
加入维修社区 - 创建账户
Node Swap
你所需要的
  1. Node Swap, Loosen front tapcon: 步骤 1 中的图像 1,2 Node Swap, Loosen front tapcon: 步骤 1 中的图像 2,2
    • the standard concrete drilled node
    • If your node is clamped or pole mounted skip to step 3
    询问修复机器人
    添加评论
  2. Node Swap, loosen back tapcon and swivel node toward you: 步骤 2 中的图像 1,1
    • with the front tapcon removed you should be able to swing the node back toward the concrete surface it's mounted on
    • you'll likely need to loosen the back tapcon and pull up on the cantilever for the node to pivot freely
    询问修复机器人
    添加评论
  3. Node Swap, remove old node: 步骤 3 中的图像 1,2 Node Swap, remove old node: 步骤 3 中的图像 2,2
    • first, note if the pin is weight bearing. if so make sure to support the node while you remove the pin (or lock)
    • pull old node out
    询问修复机器人
    添加评论
  4. Node Swap, replace with new node and measure: 步骤 4 中的图像 1,1
    • after sliding a new node in and replacing the pin or lock, measure the distance from the bottom of the ultrasonic depth sensor cone to the top of the cantilever beam. you may find a spare piece of strut to help with this.
    • you should do this before reattaching the front tapcon or clamp
    询问修复机器人
    添加评论
  5. Node Swap: 步骤 5 中的图像 1,2 Node Swap: 步骤 5 中的图像 2,2
    • Using a (weighted) tape measure, measure and record the distance from the bottom of the depth sensor node to the bottom of the river.
    • The bottom of the depth sensor node is defined as the bottom of the sensor cone.
    询问修复机器人
    添加评论
    • if node is drilled into concrete swivel the cantilever back to its full extent and reattach the front tapcon
    • if the node is clamped, reclamp the node at its full extent
    • for a pole-mounted node, you should be able to swap without altering the structure at all
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
Travis Dantzer
于05/06/21注册
266 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 26
过去 30 天: 41
总计 421
