跳转到主内容
Nobis NB09 Battery Replacement
你所需要的
  1. Nobis NB09 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Before beginning this process, make sure the device is powered off.
    • Remove the screws holding the case together.
  2. Nobis NB09 Battery Replacement: 步骤 2 中的图像 1,3 Nobis NB09 Battery Replacement: 步骤 2 中的图像 2,3 Nobis NB09 Battery Replacement: 步骤 2 中的图像 3,3
    • Use an opening tool to loosen and pry off the pink back plate.
  3. Nobis NB09 Battery Replacement: 步骤 3 中的图像 1,2 Nobis NB09 Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the black electronic tape covering the circuit board.
  4. Nobis NB09 Battery Replacement: 步骤 4 中的图像 1,1
    • Use the soldering iron to remove the black and red wires from the circuit board.
    • The black wire is the ground and the red wire is the battery positive terminal.
    • To reassemble, use the soldering iron to solder the leads at the end of the black (-) and red (+) wires from the new battery onto the proper terminals on the circuit board.
  5. Nobis NB09 Battery Replacement: 步骤 5 中的图像 1,2 Nobis NB09 Battery Replacement: 步骤 5 中的图像 2,2
    • Gently loosen the adhesive under the battery to avoid damaging it.
    • Use caution; the battery is soft and will bend very easily.
    • Dispose of the old battery properly at an electronic waste center or verified battery recycling store.
    • When reassembling, apply adhesive to the back of the new battery.
结论
3等其他人完成本指南。
Jackson McAdams
于04/01/15注册
390 声望
创作了3篇指南
团队
UMass Dartmouth, Team 7-1, Cichon Spring 2015 UMass Dartmouth, Team 7-1, Cichon Spring 2015 的会员
UMASSD-CICHON-S15S7G1
4 名成员
创作了12篇指南
一条评论
where can i buy a battery from
Frederick Shipman - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 2,958
