跳转到主内容
Nixon Mission Android Wear Battery Replacement
你所需要的
  1. Nixon Mission Android Wear Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove 4 4.5mm Phillips head screws from back side of watch using PH00 Phillips head.
  2. Nixon Mission Android Wear Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the back plate of watch.
  3. Nixon Mission Android Wear Battery Replacement: 步骤 3 中的图像 1,1
    • Unclip 5 latches from motherboard using a plastic spudger.
  4. Nixon Mission Android Wear Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the 2 3.0mm screws from motherboard using PH00 Phillips head.
  5. Nixon Mission Android Wear Battery Replacement: 步骤 5 中的图像 1,1
    • Carefully remove motherboard & internal screen.
  6. Nixon Mission Android Wear Battery Replacement: 步骤 6 中的图像 1,1
    • Remove from the motherboard the connector with the four cables.
    • Pull the cables upward and the motherboard downward as shown in the picture.
  7. Nixon Mission Android Wear Battery Replacement: 步骤 7 中的图像 1,1
    • Carefully remove the battery from the watch.
结论
6等其他人完成本指南。
团队
IUPUI, Team S3-G2, Harley Fall 2017 IUPUI, Team S3-G2, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S3G2
3 名成员
创作了3篇指南
18条评论
Hi, would you be able to advise where to purchase a replacement battery?
Simon Seow - 回复
same here, where to purchase a replacement battery ?
peter.erdogyaraki - 回复
Thank you for your tuto.
But now, where I can purchase a new battery?
Thank you
COUTURIER - 回复
Hi! Anyone knows where to buy a new battery?
cristian.carvelli - 回复
After an extensive search there doesn't seem to be any info out there about battery size…..still
Jerry Jerry J - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 57
总计 6,256
