跳转到主内容
Nite Ize Inova Microlight Casing Replacement
你所需要的
  1. Nite Ize Inova Microlight Casing Replacement, Case Removal: 步骤 1 中的图像 1,2 Nite Ize Inova Microlight Casing Replacement, Case Removal: 步骤 1 中的图像 2,2
    • Insert the plastic opening tool into the seam of the device.
  2. Nite Ize Inova Microlight Casing Replacement, Battery Removal: 步骤 2 中的图像 1,3 Nite Ize Inova Microlight Casing Replacement, Battery Removal: 步骤 2 中的图像 2,3 Nite Ize Inova Microlight Casing Replacement, Battery Removal: 步骤 2 中的图像 3,3
    • Squeeze the top battery using a tweezer and pull the battery away from the light bulb.
    • Repeat this step for the bottom remaining battery.
    • Do not pull up on the battery as this will bend the metal contact.
  3. Nite Ize Inova Microlight Casing Replacement, LED Light Removal: 步骤 3 中的图像 1,3 Nite Ize Inova Microlight Casing Replacement, LED Light Removal: 步骤 3 中的图像 2,3 Nite Ize Inova Microlight Casing Replacement, LED Light Removal: 步骤 3 中的图像 3,3
    • Place the plastic opening tool below the LED lamp and push away from the device until you hear a click.
    • Continue to remove the LED lamp the with your fingers.
  4. Nite Ize Inova Microlight Casing Replacement, Logic Board Removal: 步骤 4 中的图像 1,1
    • Place the plastic opening tool behind the logic board and bend away from the casing
  5. Nite Ize Inova Microlight Casing Replacement, Logic Board Removal: 步骤 5 中的图像 1,1
    • The logic board will pop out with ease.
结论
另外一个人完成了本指南。
团队
CSU Fullerton, Team 2-1, Bruce Fall 2014 CSU Fullerton, Team 2-1, Bruce Fall 2014 的会员
CSUF-BRUCE-F14S2G1
3 名成员
创作了3篇指南
一条评论
Great Job! found this one night while looking at my little blue light. Great tools, photos. +30
4-16-2017
F3ND1MUS - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 9
总计 827
