跳转到主内容
Nite Ize Inova Microlight Battery Replacement
你所需要的
  1. Nite Ize Inova Microlight Battery Replacement, Case Removal: 步骤 1 中的图像 1,2 Nite Ize Inova Microlight Battery Replacement, Case Removal: 步骤 1 中的图像 2,2
    • Insert the plastic opening tool into the seam of the device.
  2. Nite Ize Inova Microlight Battery Replacement, Battery Removal: 步骤 2 中的图像 1,3 Nite Ize Inova Microlight Battery Replacement, Battery Removal: 步骤 2 中的图像 2,3 Nite Ize Inova Microlight Battery Replacement, Battery Removal: 步骤 2 中的图像 3,3
    • Squeeze the top battery using a tweezer and pull the battery away from the light bulb.
    • Repeat this step for the bottom remaining battery.
    • Do not pull up on the battery as this will bend the metal contact.
结论
4等其他人完成本指南。
团队
CSU Fullerton, Team 2-1, Bruce Fall 2014 CSU Fullerton, Team 2-1, Bruce Fall 2014 的会员
CSUF-BRUCE-F14S2G1
3 名成员
创作了3篇指南
一条评论
There is another Inova flashlight design that involves removing two Phillips type screw heads that are VERY TINY. I am able to unscrew one, but not the other, so am stuck and unable to replace the batteries.
Chrystin - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 42
总计 5,573
