跳转到主内容
Nissan Versa Note Media Display System Replacement
你所需要的
  1. Nissan Versa Note Media Display System Replacement, Media Display System: 步骤 1 中的图像 1,1
    • Ensure that the car is turned off.
  2. Nissan Versa Note Media Display System Replacement: 步骤 2 中的图像 1,1
    • Pull on the switch for indoor/outdoor air to remove it.
  3. Nissan Versa Note Media Display System Replacement: 步骤 3 中的图像 1,2 Nissan Versa Note Media Display System Replacement: 步骤 3 中的图像 2,2
    • Use a spudger (or an old credit card) to gently pry the front panel away from the rest of the dash.
    • After wedging the parts apart you will see a gap.
  4. Nissan Versa Note Media Display System Replacement: 步骤 4 中的图像 1,3 Nissan Versa Note Media Display System Replacement: 步骤 4 中的图像 2,3 Nissan Versa Note Media Display System Replacement: 步骤 4 中的图像 3,3
    • Using your fingers, start from the top of the panel and move down on either side to pry the panel open.
  5. Nissan Versa Note Media Display System Replacement: 步骤 5 中的图像 1,2 Nissan Versa Note Media Display System Replacement: 步骤 5 中的图像 2,2
    • Once the panel is free from the dash, flip it over to expose the cables connected to it.
  6. Nissan Versa Note Media Display System Replacement: 步骤 6 中的图像 1,3 Nissan Versa Note Media Display System Replacement: 步骤 6 中的图像 2,3 Nissan Versa Note Media Display System Replacement: 步骤 6 中的图像 3,3
    • Remove the top cable by simply squeezing the end and pulling it out of its socket.
    • Use a spudger to push down on the tab of the bottom cable and remove it.
  7. Nissan Versa Note Media Display System Replacement: 步骤 7 中的图像 1,3 Nissan Versa Note Media Display System Replacement: 步骤 7 中的图像 2,3 Nissan Versa Note Media Display System Replacement: 步骤 7 中的图像 3,3
    • The front panel is now completely free from the dash and can be set aside.
    • Using a Phillips #3 screwdriver, remove the two screws on either side of the media system.
  8. Nissan Versa Note Media Display System Replacement: 步骤 8 中的图像 1,2 Nissan Versa Note Media Display System Replacement: 步骤 8 中的图像 2,2
    • Carefully pull out the media system and turn it over so that the cables on its rear are visible.
    • Use your hands to pinch the tabs and gently pull out each cable.
  9. Nissan Versa Note Media Display System Replacement: 步骤 9 中的图像 1,3 Nissan Versa Note Media Display System Replacement: 步骤 9 中的图像 2,3 Nissan Versa Note Media Display System Replacement: 步骤 9 中的图像 3,3
    • Now the media system is completely free from the car.
    • Using a T10 Torx screwdriver, unscrew the four screws on either side of the media system.
结论
2等其他人完成本指南。
1指南评论
Muy ilustrativo y de muchá ayuda, gracias
Juanmanuel - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 96
总计 4,346
