跳转到主内容
Nissan Kicks Repair Cabin Air Filter Replacement
你所需要的
  1. Nissan Kicks Repair Cabin Air Filter Replacement, Cabin Air Filter: 步骤 1 中的图像 1,2 Nissan Kicks Repair Cabin Air Filter Replacement, Cabin Air Filter: 步骤 1 中的图像 2,2
    • Remove the floor mat or any items in the passenger footwell of your car.
    • Use a trim tool on the inner panel beneath the glove box to release the clips and pry it out.
    • Place your hand on the far back of the panel to remove it.
    • It may require a hard tug to remove the panel.
  2. Nissan Kicks Repair Cabin Air Filter Replacement: 步骤 2 中的图像 1,2 Nissan Kicks Repair Cabin Air Filter Replacement: 步骤 2 中的图像 2,2
    • Press the tab on the bottom of the filter lid to unlock it.
    • Open the lid and pull out the old filter.
    • You may want to wear gloves or a mask in case there is a lot of debris in the filter. (Especially if it's been a long time since you last changed the filter.)
  3. Nissan Kicks Repair Cabin Air Filter Replacement: 步骤 3 中的图像 1,1
    • Insert the new filter with the arrows oriented correctly.
    • Start at the top edge of the filter, then push in the bottom, followed by the rest of the filter.
    • The direction of the arrows for the newly installed filter is dependent on what filter you purchase.
    • The arrows indicate the direction of air flow.
  4. Nissan Kicks Repair Cabin Air Filter Replacement: 步骤 4 中的图像 1,1
    • Close the lid and push the bottom in until you hear it click.
  5. Nissan Kicks Repair Cabin Air Filter Replacement: 步骤 5 中的图像 1,1
    • Replace the panel back and press firmly in the middle and around the edges to ensure it is locked in.
    • Give the panel a light tug afterward to make sure it is secure.
终点
William Do
于03/02/24注册
171 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 53
总计 117
