跳转到主内容
Nishiki Aero II Tire Removal
你所需要的
  1. Nishiki Aero II Tire Removal, Removing Road Bike Front Wheel: 步骤 1 中的图像 1,1
    • Turn the bike upside down.
  2. Nishiki Aero II Tire Removal: 步骤 2 中的图像 1,1
    • Use a wrench to loosen the nut holding the wheel's axle on one side.
    • Once it's loose enough, continue removing the nut with your hand.
  3. Nishiki Aero II Tire Removal: 步骤 3 中的图像 1,2 Nishiki Aero II Tire Removal: 步骤 3 中的图像 2,2
    • After removing the nut, also remove the washer under it.
    • Keep note of how the washer has a small appendage that locks into a slot in the fork.
  4. Nishiki Aero II Tire Removal: 步骤 4 中的图像 1,1
    • Follow the previous steps for the opposite side.
  5. Nishiki Aero II Tire Removal: 步骤 5 中的图像 1,1
    • Lift the wheel up from the fork.
  6. Nishiki Aero II Tire Removal, Nishiki Aero II Tire Removal: 步骤 6 中的图像 1,2 Nishiki Aero II Tire Removal, Nishiki Aero II Tire Removal: 步骤 6 中的图像 2,2
    • Unscrew the cap from the air valve.
    • Release the tire's air by pressing a thin object on the center pin of the valve.
    • A hex wrench or any blunt object can be used.
  7. Nishiki Aero II Tire Removal: 步骤 7 中的图像 1,3 Nishiki Aero II Tire Removal: 步骤 7 中的图像 2,3 Nishiki Aero II Tire Removal: 步骤 7 中的图像 3,3
    • Wedge a tire lever between the tire and the rim. Grab the tire with the lever's inward scoop.
    • Grab the tire's edge with the lever and pull it back to scoop the tire from the rim.
    • Keep the tire lever anchored on a spoke with the notch on the lever's opposite end.
  8. Nishiki Aero II Tire Removal: 步骤 8 中的图像 1,2 Nishiki Aero II Tire Removal: 步骤 8 中的图像 2,2
    • Repeat with an additional tire lever five inches away from the other.
  9. Nishiki Aero II Tire Removal: 步骤 9 中的图像 1,3 Nishiki Aero II Tire Removal: 步骤 9 中的图像 2,3 Nishiki Aero II Tire Removal: 步骤 9 中的图像 3,3
    • Repeat with a third tire lever farther around the tire.
    • Alternate lifting the second and third levers until the tire comes partway off.
  10. Nishiki Aero II Tire Removal: 步骤 10 中的图像 1,3 Nishiki Aero II Tire Removal: 步骤 10 中的图像 2,3 Nishiki Aero II Tire Removal: 步骤 10 中的图像 3,3
    • Wedge the tire off of the other rim with the tire levers.
    • Pull the air valve from its hole in the rim to completely remove the tire.
结论
Tobias Elder
于04/25/13注册
113 声望
创作了7篇指南
团队
Cal Poly, Team 21-53, Johann Spring 2013 Cal Poly, Team 21-53, Johann Spring 2013 的会员
CPSU-JOHANN-S13S21G53
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 22
总计 1,227
