当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
小心的把Wii的面板拉开
用镊子把LED的排线从主板拔出
移开面板
打开手柄连接口保护盖,直到它与本体垂直
把盖子直接向上拉,这样就可以拆下盖子
内存卡保护盖也是这么拆
拆掉手柄连接口边沿剩下的两颗4.1毫米十字螺丝
在四个角用手拉保护板,即可拆下
移开下列螺丝
两颗5毫米十字螺丝(红圈)
一颗8.2毫米三角螺丝(橙圈)
移开位于电池舱门上的十字螺丝
这颗螺丝承载着电池舱门
把电池舱门移开
这是一个更换CR2032纽扣电池的好时机
Use a pair of tweezers to lift the fan connector up and out of its socket on the logic board.
Be sure your tweezers are clamped down on the fan connector, not the socket on the motherboard.
Use the tip of a spudger or another fine-pointed tool to carefully pry one of the black plastic retaining fingers attached to the fan shroud away from the Wi-Fi antenna board.
Lift the Wi-Fi antenna out of the fan shroud.
Remove the following six screws securing the EMI fingers to the bottom panel:
Four 7 mm Phillips screws
Two 11.3 mm Phillips screws
Remove both sets of EMI fingers from the Wii.
Remove the following three screws:
One 7 mm Phillips screw
Two 10 mm Phillips screws
Lift the bracket out of the Wii.
Remove the three 10 mm Phillips screws securing the black bracket to the bottom panel near the front of the Wii.
Slightly lift the bracket and use your other hand to pull the retaining clip away from where the Wi-Fi antennas enter the motherboard sheild.
Remove the bracket from the Wii.
Be sure not to lose the small square nut loosely held by the black plastic bracket.
Carefully lift the motherboard cover off the motherboard, minding any cables that may get caught.
On some models, a thermal pad for the wireless chip is attached to the underside of the motherboard cover. Be sure to replace it when reassembling.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
