跳转到主内容
Nintendo Wii U Wireless and Bluetooth Module Replacement
你所需要的
  1. Nintendo Wii U Wireless and Bluetooth Module Replacement, Wireless 2.4ghz Module and Bluetooth Module: 步骤 1 中的图像 1,3 Nintendo Wii U Wireless and Bluetooth Module Replacement, Wireless 2.4ghz Module and Bluetooth Module: 步骤 1 中的图像 2,3 Nintendo Wii U Wireless and Bluetooth Module Replacement, Wireless 2.4ghz Module and Bluetooth Module: 步骤 1 中的图像 3,3
    • Locate the black or white stickers on the underside of the unit. A spudger will be used to remove these stickers to revel 9 screws.
  2. Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 2 中的图像 1,1
    • Remove the five Phillips #0 screws.
    • Remove the four Tri-Wing (Y1) screws.
  3. Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 3 中的图像 1,2 Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 3 中的图像 2,2
    • Remove the CMOS battery door on the left side of the console.
    • Remove the three Y1 Tri-Wing screws.
  4. Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 4 中的图像 1,3 Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 4 中的图像 2,3 Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 4 中的图像 3,3
    • Gently pry off the top lid of the Wii U.
  5. Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 5 中的图像 1,3 Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 5 中的图像 2,3 Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 5 中的图像 3,3
    • Rotate the device so that the front plate is facing you.
    • Remove the two Phillips #1 screws that connect the front plate to each side of the device.
  6. Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 6 中的图像 1,2 Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 6 中的图像 2,2
    • Remove the ribbon cable from the unit.
    • Separate the front plate from the main console.
  7. Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 7 中的图像 1,2 Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 7 中的图像 2,2
    • Remove the fan with a Phillips #1 by unscrewing the two connecting screws on both sides of the fan. The fan’s wires will still be attached to the motherboard as it is permanently affixed.
  8. Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 8 中的图像 1,2 Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 8 中的图像 2,2
    • Using a Phillips #0 screwdriver, unscrew the four screws (two on each side) from the disc reader connecting it to the main console and remove disc reader.
  9. Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 9 中的图像 1,3 Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 9 中的图像 2,3 Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 9 中的图像 3,3
    • Unscrew and remove the heatsink. You will have to carefully move the antenna cables out of the way in order to remove the heatsink shielding.
  10. Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 10 中的图像 1,2 Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 10 中的图像 2,2
    • Using a Phillips #1 unscrew all floor screws connecting the outer plate from the circuit board to remove the circuit board.
  11. Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 11 中的图像 1,2 Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 11 中的图像 2,2
    • Using a Phillips #1 unscrew the 4 screws securing the heatsink to the motherboard and remove the heatsink.
  12. Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 12 中的图像 1,2 Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 12 中的图像 2,2
    • Locate the screws lining the perimeter of the motherboard that you will remove with a Phillips #1 screwdriver. Once they are unscrewed, the motherboard should easily separate from the lower tray.
    • Once the motherboard is detached, flip it over to view the wireless modules.
  13. Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 13 中的图像 1,3 Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 13 中的图像 2,3 Nintendo Wii U Wireless and Bluetooth Module Replacement: 步骤 13 中的图像 3,3
    • Pull up gently on the wireless modules to avoid breakage.
结论
9等其他人完成本指南。
Jana Miles
于02/24/16注册
326 声望
撰写一个指南
团队
USF Tampa, Team 1-2, Leahy Spring 2016 USF Tampa, Team 1-2, Leahy Spring 2016 的会员
USFT-LEAHY-S16S1G2
3 名成员
创作了15篇指南
7指南评论
GamePad module is model: MIC-B2 (5GHz) (BCM43237KMLG).
WiFi module is model: WIN-A2 (2.4GHz) (BCM43362KUBG).
Bluetooth module is model: WIN-B2 (BCM20702).
phacox.cll - 回复
Great guide with clear pictures!
Question: Does the Wii U operate correctly without WiFi and without Bluetooth modules? Of course, no connection can be established thru these modules when they were removed, but, does all the other stuff work correctly and you can play your games as usual?
Bert Zweistein - 回复
I am thinking you wouldn't be able to use any controllers if you did so because of their reliance on the Bluetooth module, no? I am not sure if the Gamepad controller uses only 5GHz wifi only or Bluetooth too
IronGumby -
So after wasting quite a bit of my life looking for these parts. Here are the part numbers that you should type into the good ole Google machine or Ebay if you are looking to purchase these parts.
GamePad module (5GHz) : 2878D-MIC-B2
WiFi module (2.4GHz) Part number is: 2878D-WIN-A2
Bluetooth module Part number is: 2878D-WIN-B2
Just some dude - 回复
How in the world am I expected to get these 2 cables off of the bluetooth adapter? I do not want to break them off but I do not think they twist off either
Shawn Berry - 回复
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 57
过去 30 天: 227
总计 14,315
