跳转到主内容
加入维修社区 - 创建账户
Nintendo Wii U Wireless Module Replacement
你所需要的
  1. Nintendo Wii U Wireless Module Replacement, Console Outer Case: 步骤 1 中的图像 1,1
    • With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
    • Three 5.1mm Phillips #000 screws
    • Two 6.1mm Tri-wing Y0 screws
    • One 13.2mm Tri-wing Y1 screw
  2. Nintendo Wii U Wireless Module Replacement: 步骤 2 中的图像 1,1
    • Rotate the console 180 degrees so that the exhaust vents are facing you.
    • Remove the two 7.1mm Phillips #00 screws.
  3. Nintendo Wii U Wireless Module Replacement: 步骤 3 中的图像 1,2 Nintendo Wii U Wireless Module Replacement: 步骤 3 中的图像 2,2
    • On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
  4. Nintendo Wii U Wireless Module Replacement: 步骤 4 中的图像 1,1
    • On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
  5. Nintendo Wii U Wireless Module Replacement: 步骤 5 中的图像 1,3 Nintendo Wii U Wireless Module Replacement: 步骤 5 中的图像 2,3 Nintendo Wii U Wireless Module Replacement: 步骤 5 中的图像 3,3
    • On the back of the console, lift up and release the main top cover.
  6. Nintendo Wii U Wireless Module Replacement, Front Faceplate: 步骤 6 中的图像 1,2 Nintendo Wii U Wireless Module Replacement, Front Faceplate: 步骤 6 中的图像 2,2
    • Rotate the device so that the front plate is facing you.
    • On each side of the console, remove the 3.5mm Phillips #0 screw connecting the DVD drive to the faceplate.
  7. Nintendo Wii U Wireless Module Replacement: 步骤 7 中的图像 1,1
    • Rotate the device so that the front plate is on the right side and the ribbon cable is visible.
    • The ribbon cable is connected to the system by a latch which holds in the blue tab. Flip this latch up to unlock it.
    • Lift up on the blue tab to release the ribbon cable.
  8. Nintendo Wii U Wireless Module Replacement: 步骤 8 中的图像 1,1
    • Remove the front faceplate.
  9. Nintendo Wii U Wireless Module Replacement, DVD Drive: 步骤 9 中的图像 1,1
    • On each side of the DVD drive, remove the two 4.6mm Phillips #0 mounting screws.
  10. Nintendo Wii U Wireless Module Replacement: 步骤 10 中的图像 1,2 Nintendo Wii U Wireless Module Replacement: 步骤 10 中的图像 2,2
    • Rotate the device so that the disc drive slot is visible.
    • A ribbon cable is attached to the bottom right side of the disc drive. The ribbon cable can rip if it isn't removed properly.
    • Lift the disc drive out of the mount and turn over to the right so it lies like a book.
    • Use a spudger to release the ribbon cable.
  11. Nintendo Wii U Wireless Module Replacement: 步骤 11 中的图像 1,1
    • Remove the disc drive.
  12. Nintendo Wii U Wireless Module Replacement, Motherboard: 步骤 12 中的图像 1,3 Nintendo Wii U Wireless Module Replacement, Motherboard: 步骤 12 中的图像 2,3 Nintendo Wii U Wireless Module Replacement, Motherboard: 步骤 12 中的图像 3,3
    • Remove the black plastic shielding by unscrewing connecting screws with a Phillip's Head screwdriver.
    • You will have to carefully adjust the antenna cables out of the way in order to proceed comfortably.
  13. Nintendo Wii U Wireless Module Replacement: 步骤 13 中的图像 1,3 Nintendo Wii U Wireless Module Replacement: 步骤 13 中的图像 2,3 Nintendo Wii U Wireless Module Replacement: 步骤 13 中的图像 3,3
    • The metal cap does not require unscrewing and should lift up with ease.
    • Unscrew all the screws that outline the perimeter of the board using a Phillips Head (PH1) screwdriver.
    • Remove the silver shielding plate once all screws are removed. Be careful when pulling it under the affixed antenna cables.
  14. Nintendo Wii U Wireless Module Replacement: 步骤 14 中的图像 1,2 Nintendo Wii U Wireless Module Replacement: 步骤 14 中的图像 2,2
    • At this point, the motherboard should easily separate from the lower tray.
  15. Nintendo Wii U Wireless Module Replacement, Wireless 5ghz Module: 步骤 15 中的图像 1,3 Nintendo Wii U Wireless Module Replacement, Wireless 5ghz Module: 步骤 15 中的图像 2,3 Nintendo Wii U Wireless Module Replacement, Wireless 5ghz Module: 步骤 15 中的图像 3,3
    • Flip the motherboard over to view the underside where the Wii U's wireless modules are located. The Bluetooth module is circled in red.
    • This module is affixed with strong adhesive, so in order to remove it you will need to wiggle the module with slight force for a couple of minutes.
结论
4等其他人完成本指南。
Emily Vasquez
于02/24/16注册
980 声望
创作了3篇指南
团队
USF Tampa, Team 1-2, Leahy Spring 2016 USF Tampa, Team 1-2, Leahy Spring 2016 的会员
USFT-LEAHY-S16S1G2
3 名成员
创作了15篇指南
14指南评论
Where would be able to buy this replacement part? Anyone know?
Salvador Mora - 回复 分享
I found on aliexpress
Rodrigo Mafort - 分享
I actually just bought a secondary Wii U just to be sure I don't get a cheap part, it was like $65 with a credit on eBay
Salvador Mora - 分享
Which one of these is for the module for control pad?:
Broadcom BCM43237KMLG Wireless LAN module
Broadcom BCM43362KUB6 802.11n Wireless Module—the same one used in the Roku 2 XS
Broadcom BCM20702 Bluetooth 4.0
Dan - 回复 分享
bcm43362kub6
Rodrigo Mafort - 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 61
过去 30 天: 198
总计 13,884
