跳转到主内容
加入维修社区 - 创建账户
Nintendo Wii U GamePad Directional Pad Buttons Replacement
你所需要的
  1. Nintendo Wii U GamePad Directional Pad Buttons Replacement, Back Panel: 步骤 1 中的图像 1,3 Nintendo Wii U GamePad Directional Pad Buttons Replacement, Back Panel: 步骤 1 中的图像 2,3 Nintendo Wii U GamePad Directional Pad Buttons Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Remove the ten 8.9mm Tri-point Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
  2. Nintendo Wii U GamePad Directional Pad Buttons Replacement: 步骤 2 中的图像 1,2 Nintendo Wii U GamePad Directional Pad Buttons Replacement: 步骤 2 中的图像 2,2
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back panel.
  3. Nintendo Wii U GamePad Directional Pad Buttons Replacement, Analog Stick: 步骤 3 中的图像 1,2 Nintendo Wii U GamePad Directional Pad Buttons Replacement, Analog Stick: 步骤 3 中的图像 2,2
    • Take out the left and right shoulder buttons in the upper corners.
    • Remove the ZR and ZL trigger buttons by lifting up and sliding outward.
  4. Nintendo Wii U GamePad Directional Pad Buttons Replacement: 步骤 4 中的图像 1,2 Nintendo Wii U GamePad Directional Pad Buttons Replacement: 步骤 4 中的图像 2,2
    • Remove the top rubber cover by pulling it off of its mounts to access one of the mounting screws.
    • Remove the four 5.2mm Phillips #0 screws.
  5. Nintendo Wii U GamePad Directional Pad Buttons Replacement: 步骤 5 中的图像 1,2 Nintendo Wii U GamePad Directional Pad Buttons Replacement: 步骤 5 中的图像 2,2
    • Use a spudger to lift the tab which releases the blue ribbon cable.
    • Remove the analog stick and button cover.
  6. Nintendo Wii U GamePad Directional Pad Buttons Replacement: 步骤 6 中的图像 1,1
    • Use your thumb and push the connector towards the rightmost edge to disconnect the analog stick cable connector.
  7. Nintendo Wii U GamePad Directional Pad Buttons Replacement: 步骤 7 中的图像 1,2 Nintendo Wii U GamePad Directional Pad Buttons Replacement: 步骤 7 中的图像 2,2
    • Remove the two 9.0mm Tri-point Y0 screws.
    • Lift out the analog stick.
  8. Nintendo Wii U GamePad Directional Pad Buttons Replacement, Directional Pad Buttons: 步骤 8 中的图像 1,2 Nintendo Wii U GamePad Directional Pad Buttons Replacement, Directional Pad Buttons: 步骤 8 中的图像 2,2
    • Lift up and remove the rubber cover for the directional pad.
    • Remove the directional pad buttons.
结论
12等其他人完成本指南。
Kim Arre
于01/11/13注册
5,700 声望
创作了8篇指南
团队
Cal Poly, Team 17-20, Forte Winter 2013 Cal Poly, Team 17-20, Forte Winter 2013 的会员
CPSU-FORTE-W13S17G20
5 名成员
创作了41篇指南
1指南评论
Where can you find the blue ribbon mentioned in step 5, for the buttons at?
Eric - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 39
过去 30 天: 155
总计 23,329
