跳转到主内容
Nintendo Wii U GamePad Analog Stick Replacement
你所需要的
  1. Nintendo Wii U GamePad Analog Stick Replacement, Battery: 步骤 1 中的图像 1,2 Nintendo Wii U GamePad Analog Stick Replacement, Battery: 步骤 1 中的图像 2,2
    • Face the GamePad down and unscrew the two 4.7 mm Phillips #00 screws which are attached to the battery cover.
    • Lift up and remove the battery cover.
  2. Nintendo Wii U GamePad Analog Stick Replacement: 步骤 2 中的图像 1,3 Nintendo Wii U GamePad Analog Stick Replacement: 步骤 2 中的图像 2,3 Nintendo Wii U GamePad Analog Stick Replacement: 步骤 2 中的图像 3,3
    • With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
    • Pull upwards from the bottom of the battery to release it.
  3. Nintendo Wii U GamePad Analog Stick Replacement, Back Panel: 步骤 3 中的图像 1,3 Nintendo Wii U GamePad Analog Stick Replacement, Back Panel: 步骤 3 中的图像 2,3 Nintendo Wii U GamePad Analog Stick Replacement, Back Panel: 步骤 3 中的图像 3,3
    • Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
  4. Nintendo Wii U GamePad Analog Stick Replacement: 步骤 4 中的图像 1,2 Nintendo Wii U GamePad Analog Stick Replacement: 步骤 4 中的图像 2,2
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back panel.
  5. Nintendo Wii U GamePad Analog Stick Replacement, Analog Stick: 步骤 5 中的图像 1,2 Nintendo Wii U GamePad Analog Stick Replacement, Analog Stick: 步骤 5 中的图像 2,2
    • Take out the left and right shoulder buttons in the upper corners.
    • Remove the ZR and ZL trigger buttons by lifting up and sliding outward.
  6. Nintendo Wii U GamePad Analog Stick Replacement: 步骤 6 中的图像 1,2 Nintendo Wii U GamePad Analog Stick Replacement: 步骤 6 中的图像 2,2
    • Remove the top rubber cover by pulling it off of its mounts to access one of the mounting screws.
    • Remove the four 5.2mm Phillips #0 screws.
  7. Nintendo Wii U GamePad Analog Stick Replacement: 步骤 7 中的图像 1,2 Nintendo Wii U GamePad Analog Stick Replacement: 步骤 7 中的图像 2,2
    • Use a spudger to lift the tab which releases the blue ribbon cable.
    • Remove the analog stick and button cover.
  8. Nintendo Wii U GamePad Analog Stick Replacement: 步骤 8 中的图像 1,1
    • Use your thumb and push the connector towards the rightmost edge to disconnect the analog stick cable connector.
  9. Nintendo Wii U GamePad Analog Stick Replacement: 步骤 9 中的图像 1,2 Nintendo Wii U GamePad Analog Stick Replacement: 步骤 9 中的图像 2,2
    • Remove the two 9.0mm Tri-wing Y0 screws.
    • Lift out the analog stick.
结论
85等其他人完成本指南。
Kim Arre
于01/11/13注册
5,017 声望
创作了8篇指南
团队
Cal Poly, Team 17-20, Forte Winter 2013 Cal Poly, Team 17-20, Forte Winter 2013 的会员
CPSU-FORTE-W13S17G20
5 名成员
创作了39篇指南
35条评论
where can i find replacement analogs for wiiu gamepad and wiiu procontoller?
Victor Torres - 回复
www.ebay.com
mhuntersr -
They are available at ebay.com Cost around 7,50 $ Left & Right (different - look what you need). Comes all from china or hong Kong but Quality is 1A (so far i can tell).
Frederik Rischmann -
Bump previous question because dogs seem to enjoy their texture.
maskedpainter - 回复
Has anyone tried this?
http://dx.com/p/replacement-3d-analog-st...
I know it says for the pro controller. But based from the images, the pins could be compatible.
wandererwk - 回复
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 107
过去 30 天: 529
总计 101,493
