简介
Use this guide to install a new front faceplate for the Nintendo Wii U.
你所需要的
With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
Three 5.1mm Phillips #000 screws
Two 6.1mm Tri-wing Y0 screws
One 13.2mm Tri-wing Y1 screw
Rotate the device so that the front plate is facing you.
On each side of the console, remove the 3.5mm Phillips #0 screw connecting the DVD drive to the faceplate.
11等其他人完成本指南。
4指南评论
Great guide. I was able to fix the front USB door on my Wii u! Thanks guys!
Matt Jones - 回复
My ribbon seems to work but the little connection it plugs into on the circuit board in the console broke off. Not just the black clip but the whole little circuit. Seems like a clean break. Can I solder it back on? If I push it back on and hold the ribbon in the red light comes on and blinks. Occasionally I can get the white light to come on for like a second but I never hear fans spinning/more of the unit coming to life before it shuts itself off.
Thoughts on how to fix it?
My daughter shoved change into my disc slot of my Wii I. I thought I got out all pulling through the faceplate dvd slot but now when I put in a game disc it won’t catcalls accept it. It pulls in, sounds like it turns a little bit and then ejects the disc. Could change still be stuck in the reader or do I need to replace it now?
Bit sad that it doesn't show how to re-insert the little ribbon cable. The tiny black latch came off, and there's no way to refix the latch back to the connector.
Regards,
Adrie
Adrie Lute - 回复
