跳转到主内容
Nintendo Wii U Console Outer Case Replacement
你所需要的
  1. Nintendo Wii U Console Outer Case Replacement, Console Outer Case: 步骤 1 中的图像 1,1
    • With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
    • Three 5.1mm Phillips #000 screws
    • Two 6.1mm Tri-wing Y0 screws
    • One 13.2mm Tri-wing Y1 screw
  2. Nintendo Wii U Console Outer Case Replacement: 步骤 2 中的图像 1,1
    • Rotate the console 180 degrees so that the exhaust vents are facing you.
    • Remove the two 7.1mm Phillips #00 screws.
  3. Nintendo Wii U Console Outer Case Replacement: 步骤 3 中的图像 1,2 Nintendo Wii U Console Outer Case Replacement: 步骤 3 中的图像 2,2
    • On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
  4. Nintendo Wii U Console Outer Case Replacement: 步骤 4 中的图像 1,1
    • On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
  5. Nintendo Wii U Console Outer Case Replacement: 步骤 5 中的图像 1,3 Nintendo Wii U Console Outer Case Replacement: 步骤 5 中的图像 2,3 Nintendo Wii U Console Outer Case Replacement: 步骤 5 中的图像 3,3
    • On the back of the console, lift up and release the main top cover.
结论
27等其他人完成本指南。
Kim Arre
于01/11/13注册
4,918 声望
创作了8篇指南
团队
Cal Poly, Team 17-20, Forte Winter 2013 Cal Poly, Team 17-20, Forte Winter 2013 的会员
CPSU-FORTE-W13S17G20
5 名成员
创作了38篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 78
过去 30 天: 382
总计 32,131
