跳转到主内容
加入维修社区 - 创建账户
Nintendo Wii U Button Replacement
你所需要的
  1. Nintendo Wii U Button Replacement, Button Replacement: 步骤 1 中的图像 1,2 Nintendo Wii U Button Replacement, Button Replacement: 步骤 1 中的图像 2,2
    • You will first need to find all the screws hidden underneath the black (or white) square stickers. They are all located on the bottom side of the Wii U.
    • Use a spudger to remove the stickers if it is difficult to peel off with your fingers.
  2. Nintendo Wii U Button Replacement: 步骤 2 中的图像 1,1
    • Remove the five Phillips #0 screws.
    • Remove the four Tri-Wing Y1 screws.
  3. Nintendo Wii U Button Replacement: 步骤 3 中的图像 1,2 Nintendo Wii U Button Replacement: 步骤 3 中的图像 2,2
    • Remove the CMOS battery door on the left side of the console.
    • Once the door is removed, remove the three Phillips #0 screws.
  4. Nintendo Wii U Button Replacement: 步骤 4 中的图像 1,3 Nintendo Wii U Button Replacement: 步骤 4 中的图像 2,3 Nintendo Wii U Button Replacement: 步骤 4 中的图像 3,3
    • Gently pry off the top lid of the Wii U.
  5. Nintendo Wii U Button Replacement: 步骤 5 中的图像 1,3 Nintendo Wii U Button Replacement: 步骤 5 中的图像 2,3 Nintendo Wii U Button Replacement: 步骤 5 中的图像 3,3
    • Rotate the device so that the front plate is facing you.
    • Remove the two Phillips #1 screws.
  6. Nintendo Wii U Button Replacement: 步骤 6 中的图像 1,3 Nintendo Wii U Button Replacement: 步骤 6 中的图像 2,3 Nintendo Wii U Button Replacement: 步骤 6 中的图像 3,3
    • Remove the ribbon cable and separate the front plate from the main console.
  7. Nintendo Wii U Button Replacement: 步骤 7 中的图像 1,1
    • Remove the three Phillips #1 screws.
  8. Nintendo Wii U Button Replacement: 步骤 8 中的图像 1,1
    • Once unscrewed, remove the black braces that hold the power button, eject button, and sync button in place.
  9. Nintendo Wii U Button Replacement: 步骤 9 中的图像 1,1
    • Remove the desired button(s).
结论
Emily Vasquez
于02/24/16注册
980 声望
创作了3篇指南
团队
USF Tampa, Team 1-2, Leahy Spring 2016 USF Tampa, Team 1-2, Leahy Spring 2016 的会员
USFT-LEAHY-S16S1G2
3 名成员
创作了15篇指南
1指南评论
Anyone know what that ribbon cable is in step 6? Just regular 9 pin?
Lugi - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 108
总计 5,836
