当前版本的文档还未经巡查,您可以查看最新的已查核版本。
将Wii手柄翻面,将电池盖对准自己
将底部推开
移除电池盖
从第一块电池的正极处按下并拔出电池
从第二块电池的正极处向上推并拔出电池
Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
Repeat with the two bottom screws.
With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
These tabs are breakable. However, if the tabs are broken the controller will still function.
Open the front plate like a book.
Small parts may fall out as you open the front plate.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
