简介
Removing the speaker requires opening the case of the Wii Remote.
你所需要的
Flip the Wii Remote over so the battery cover faces you.
Push up on the bottom tab.
Remove the battery cover.
With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
Open the front plate like a book.
Mine is not opening like a book? What do I do?
It stops short of explaining replacing rechargeable battery. Unless you’re referring to the AA’s which don’t involve removing cover
Place the plastic opening tool between the edge of the speaker and the wii remote.
Gently lift the speaker out of the body of the Wii remote.
In my Wii controller, the speaker is connected to two cables instead of touching the motherboard.
Santi12008 - 回复
另外一个人完成了本指南。
