跳转到主内容
Nintendo Wii Remote Sensor Screen Replacement
你所需要的
  1. Nintendo Wii Remote Sensor Screen Replacement, Front Cover Plate and Batteries: 步骤 1 中的图像 1,2 Nintendo Wii Remote Sensor Screen Replacement, Front Cover Plate and Batteries: 步骤 1 中的图像 2,2
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
  2. Nintendo Wii Remote Sensor Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Nintendo Wii Remote Sensor Screen Replacement: 步骤 3 中的图像 1,1
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. Nintendo Wii Remote Sensor Screen Replacement: 步骤 4 中的图像 1,2 Nintendo Wii Remote Sensor Screen Replacement: 步骤 4 中的图像 2,2
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    Mine is not opening like a book? What do I do?
    Micah Thompson - 回复
    It stops short of explaining replacing rechargeable battery. Unless you’re referring to the AA’s which don’t involve removing cover
    Sticky Insides - 回复
  5. Nintendo Wii Remote Sensor Screen Replacement, Sensor Screen: 步骤 5 中的图像 1,3 Nintendo Wii Remote Sensor Screen Replacement, Sensor Screen: 步骤 5 中的图像 2,3 Nintendo Wii Remote Sensor Screen Replacement, Sensor Screen: 步骤 5 中的图像 3,3
    • Tilt the remote, without the front cover plate, upward so the handle strap is at the bottom and the black screen is facing you.
    • Grip the outward edge of the screen with your fingers.
    • Gently, pull the screen straight outward from its housing. The screen will slide directly out.
结论
11等其他人完成本指南。
Emily
于04/14/13注册
1,524 声望
创作了6篇指南
团队
Cal Poly, Team 3-44, Amido Spring 2013 Cal Poly, Team 3-44, Amido Spring 2013 的会员
CPSU-AMIDO-S13S3G44
4 名成员
创作了26篇指南
2条评论
Where can the screen be purchased??
cutsiepie6480 - 回复
how is this moderate difficulty
Sqwerks - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 40
过去 30 天: 232
总计 20,486
