跳转到主内容
简介
Disassembling the case requires removing screws under the batteries. Removing anything inside requires this guide.
配件
没有特定配件。
  1. Flip the Wii Remote over so the battery cover faces you. Push up on the bottom tab.
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
  2. Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller. These tabs are breakable. However, if the tabs are broken the controller will still function.
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
结论
20等其他人完成本指南。
Emily
于2013年04月14日注册
945 信誉积分
创作了6篇指南
团队
Cal Poly, Team 3-44, Amido Spring 2013 Cal Poly, Team 3-44, Amido Spring 2013 的会员
CPSU-AMIDO-S13S3G44
4 名成员
创作了18篇指南
4条评论
Worked! Had to solder the tab to contact the battery which had broken. Saved $50.00.
Graham Poor - 回复
The Tools section lists a Tri-Point Y1 Screwdriver but the guide mentions a Tri-Wing Y1 Screwdriver. This could cause people to purchase the wrong item.
iFixit’s guides seem to be based on the original Wii controller, model RVL-003. I’m not sure if Nintendo has changed fasteners for subsequent versions but the Wii MotionPlus Controller, model RVL-036, uses a Tri-Wing Y0 screw.
kivrin - 回复
@kivrin Thanks for your comment. I’m pretty sure it should say tri-point, not tri-wing. I’ll update the instructions. Tri-wing screws have a more twisted/triangular form factor, like this.
Jeff Suovanen -
My controller (the original) had three tri-wing screws and one philips. Not sure why. Had to re-solder the negative battery terminal as it came off the bottom of the ‘top’ (faces bottom) of the board.
audvare - 回复
添加评论
浏览统计数据:
过去的24小时: 14
过去的7天: 81
过去的30天: 299
总计 61,798
