跳转到主内容
Nintendo Wii Remote Disassembly and Corrosion Cleaning
你所需要的
  1. Nintendo Wii Remote Disassembly and Corrosion Cleaning, Nintendo Wii Remote Disassembly and Corrosion Cleaning: 步骤 1 中的图像 1,3 Nintendo Wii Remote Disassembly and Corrosion Cleaning, Nintendo Wii Remote Disassembly and Corrosion Cleaning: 步骤 1 中的图像 2,3 Nintendo Wii Remote Disassembly and Corrosion Cleaning, Nintendo Wii Remote Disassembly and Corrosion Cleaning: 步骤 1 中的图像 3,3
    • Remove the battery cover and the batteries.
    • Remove the four tri-point Y1 screws holding the remote together.
  2. Nintendo Wii Remote Disassembly and Corrosion Cleaning: 步骤 2 中的图像 1,3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: 步骤 2 中的图像 2,3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: 步骤 2 中的图像 3,3
    • Using an opening tool, apply pressure to the tabs located near the "A" button.
    • The tabs can break, but the remote will still work even if they do break.
    • Remove the faceplate.
  3. Nintendo Wii Remote Disassembly and Corrosion Cleaning: 步骤 3 中的图像 1,3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: 步骤 3 中的图像 2,3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: 步骤 3 中的图像 3,3
    • To remove the motherboard, press up on the "B" button, and then the connector at the bottom.
  4. Nintendo Wii Remote Disassembly and Corrosion Cleaning: 步骤 4 中的图像 1,3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: 步骤 4 中的图像 2,3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: 步骤 4 中的图像 3,3
    • Unclip the tabs to remove the plastic piece.
    • On the back, move the vibration motor out of the way to completely remove the plastic piece.
  5. Nintendo Wii Remote Disassembly and Corrosion Cleaning: 步骤 5 中的图像 1,3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: 步骤 5 中的图像 2,3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: 步骤 5 中的图像 3,3
    • Find any corrosion on the motherboard.
    • Corrosion on the motherboard will have a blueish color and may appear in multiple places.
    • Check the battery terminals for corrosion.
    • If batteries leaked in the remote, there will be corrosion on the terminals.
  6. Nintendo Wii Remote Disassembly and Corrosion Cleaning: 步骤 6 中的图像 1,3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: 步骤 6 中的图像 2,3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: 步骤 6 中的图像 3,3
    • Clean the corroded areas with isopropyl alcohol and a toothbrush.
    • Q-tips can be used instead of a toothbrush.
    • Cleaning won't make look it perfect, but the remote will work again.
  7. Nintendo Wii Remote Disassembly and Corrosion Cleaning: 步骤 7 中的图像 1,2 Nintendo Wii Remote Disassembly and Corrosion Cleaning: 步骤 7 中的图像 2,2
    • Clean the terminals with isopropyl alcohol and a toothbrush or Q-tips.
    • It is difficult to remove this piece, so clean it as good as you can. Using more isopropyl alcohol helps here.
结论
11等其他人完成本指南。
2条评论
Would 99% Isopropyl Alcohol also be okay to use as cleaner?
Mirela - 回复
Of course, I use this for cleaning every type of motherboard, the difference between 99% and 70% is that the solution contains less water, so the liquid evaporate in less time :)
ReDeath_ -
添加评论
浏览统计数据:
过去 24 小时: 26
过去 7 天: 215
过去 30 天: 880
总计 19,744
