跳转到主内容
Nintendo Wii Remote B Trigger Button Replacement
你所需要的
  1. Nintendo Wii Remote B Trigger Button Replacement, Front Cover Plate and Batteries: 步骤 1 中的图像 1,2 Nintendo Wii Remote B Trigger Button Replacement, Front Cover Plate and Batteries: 步骤 1 中的图像 2,2
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
  2. Nintendo Wii Remote B Trigger Button Replacement: 步骤 2 中的图像 1,1
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Nintendo Wii Remote B Trigger Button Replacement: 步骤 3 中的图像 1,1
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. Nintendo Wii Remote B Trigger Button Replacement: 步骤 4 中的图像 1,2 Nintendo Wii Remote B Trigger Button Replacement: 步骤 4 中的图像 2,2
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
  5. Nintendo Wii Remote B Trigger Button Replacement, Motherboard: 步骤 5 中的图像 1,2 Nintendo Wii Remote B Trigger Button Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Using the connector port, gently lift the motherboard about 2 cm from the base.
    • Electrostatic discharge may damage the device. Be careful and avoid touching the electronic components as much as possible.
  6. Nintendo Wii Remote B Trigger Button Replacement: 步骤 6 中的图像 1,2 Nintendo Wii Remote B Trigger Button Replacement: 步骤 6 中的图像 2,2
    • Grasp the edges of the motherboard and pull it straight away from the case.
  7. Nintendo Wii Remote B Trigger Button Replacement, B Trigger Button: 步骤 7 中的图像 1,2 Nintendo Wii Remote B Trigger Button Replacement, B Trigger Button: 步骤 7 中的图像 2,2
    • Locate the black sensor screen found at the bottom end of the Wii remote.
    • Grip the free edge of the black sensor screen and gently pull it down to remove from the Wii control.
  8. Nintendo Wii Remote B Trigger Button Replacement: 步骤 8 中的图像 1,2 Nintendo Wii Remote B Trigger Button Replacement: 步骤 8 中的图像 2,2
    • Find the two small tabs near the front end of the white plastic housing.
    • Place the flat end of the spudger tool under one tab and lightly push up until the tabs pop out of place.
  9. Nintendo Wii Remote B Trigger Button Replacement: 步骤 9 中的图像 1,1
    • Flip the remote over and the plastic B trigger will fall out.
    • Catch the plastic trigger so it does not get lost.
  10. Nintendo Wii Remote B Trigger Button Replacement: 步骤 10 中的图像 1,3 Nintendo Wii Remote B Trigger Button Replacement: 步骤 10 中的图像 2,3 Nintendo Wii Remote B Trigger Button Replacement: 步骤 10 中的图像 3,3
    • Flip the motherboard so that the rumble motor and the white plastic housing face up.
    • Place the flat end of the spudger tool under the round rumble motor and lightly push up.
    • Tilt the motherboard to the left and the rumble motor will fall out of the white housing.
    • Do not pull the rumble motor out, this could cause the wires to rip from the motherboard.
  11. Nintendo Wii Remote B Trigger Button Replacement: 步骤 11 中的图像 1,3 Nintendo Wii Remote B Trigger Button Replacement: 步骤 11 中的图像 2,3 Nintendo Wii Remote B Trigger Button Replacement: 步骤 11 中的图像 3,3
    • Flip the motherboard over and locate the two white tabs at the top the plastic housing.
    • Place both thumbs on the inside of the tabs and push the tabs outward.
    • Use the inner sides of your thumbs to separate the motherboard from the plastic housing.
  12. Nintendo Wii Remote B Trigger Button Replacement: 步骤 12 中的图像 1,2 Nintendo Wii Remote B Trigger Button Replacement: 步骤 12 中的图像 2,2
    • Gently push the rubber button out of the plastic housing.
    • The rubber button is bouncy, so be cautious after pushing it out.
结论
2等其他人完成本指南。
Emily
于04/14/13注册
1,923 声望
创作了6篇指南
团队
Cal Poly, Team 3-44, Amido Spring 2013 Cal Poly, Team 3-44, Amido Spring 2013 的会员
CPSU-AMIDO-S13S3G44
4 名成员
创作了29篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 84
总计 19,354
