跳转到主内容
Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly
你所需要的
  1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly, Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 1 中的图像 1,3 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly, Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 1 中的图像 2,3 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly, Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 1 中的图像 3,3
    • Remove the battery cover from the remote and batteries inside.
    • Unscrew the four visible screws on the remote. These are Y1 tri-point screws.
  2. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 2 中的图像 1,3 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 2 中的图像 2,3 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 2 中的图像 3,3
    • Use a tool to gently pry apart the white tabs near the top of the controller.
    • Once you open up the remote, there should now be two separate pieces.
    • The tabs may break off, but the remote will still be able to function without them.
  3. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 3 中的图像 1,2 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 3 中的图像 2,2
    • Use a tool or your fingers to remove the speaker piece from the remote.
    • Be careful not to puncture the speaker! This won't render it unuseable BUT will slowly start to sound worse.
  4. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 4 中的图像 1,1
    • Simply remove the rest of the buttons and the flexible plastic covering.
    • These buttons are very small and easily lost so be sure to keep them organized and close for easy access.
  5. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 5 中的图像 1,3 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 5 中的图像 2,3 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 5 中的图像 3,3
    • Go back to the side of the remote with the motherboard.
    • Gently lift and remove it from the base.
    • Be gentle while pulling out, being sure not to rip off the wires from the rumble motor.
  6. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 6 中的图像 1,2 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 6 中的图像 2,2
    • Pull out the sensor screen.
  7. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 7 中的图像 1,3 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 7 中的图像 2,3 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 7 中的图像 3,3
    • Find the white tabs facing where the sensor screen was.
    • Place a tool under one tab and push up until both tabs pop out of place, and remove the B trigger.
  8. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 8 中的图像 1,2 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 8 中的图像 2,2
    • Use a tool and place it under the rumble motor. Gently lift and remove it from the plastic housing.
    • Be careful while removing. Do not remove any of the wires from the rumble motor.
  9. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 9 中的图像 1,2 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 9 中的图像 2,2
    • To remove the plastic housing, you have to locate the two white tabs. Use your thumbs to gently pull them apart and remove the plastic housing.
    • Remove the rubber button from the plastic housing.
  10. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 10 中的图像 1,2 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 10 中的图像 2,2
    • You should now have all the pieces detached from the Wii remote.
    • You should have all the piece shown in the photos to the left.
  11. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 11 中的图像 1,3 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 11 中的图像 2,3 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 11 中的图像 3,3
    • My partner will now be putting back together the remote while only following the previous instructions I have made.
    • Return the the buttons back to their original spot along with the flexible plastic covering on top.
  12. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 12 中的图像 1,1
    • Place the rubber button under the plastic housing.
    • Align the two white tabs with the two indents on the sides and slide the plastic housing into place.
    • Put back the rumble motor back to its original spot.
    • Make sure your are putting the white plastic housing on the correct side of the motherboard as it was at the start.
  13. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 13 中的图像 1,2 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 13 中的图像 2,2
    • Return the sensor screen to its spot and slide it back into place.
    • Make sure the sensor screen is facing the right way.
  14. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 14 中的图像 1,2 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 14 中的图像 2,2
    • Place the B trigger back into its spot and click the two white tabs into place.
  15. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 15 中的图像 1,3 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 15 中的图像 2,3 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 15 中的图像 3,3
    • Lay the motherboard on top of the back side of the remote and push down gently til in place.
    • Be sure that the rumble motor is facing down while putting it back in place.
  16. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 16 中的图像 1,3 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 16 中的图像 2,3 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 16 中的图像 3,3
    • Lay the side of the remote with the motherboard on top of the side with the buttons.
    • Align the sides and press together until firmly in place.
    • Screw back in the screws.
  17. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly, Now for the Wii Nunchuk: 步骤 17 中的图像 1,2 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly, Now for the Wii Nunchuk: 步骤 17 中的图像 2,2
    • there are two small screws that need to be unscrewed on the bottom of the remote.
  18. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 18 中的图像 1,2 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 18 中的图像 2,2
    • Once the screws are removed, you can pop the top off.
    • Next take the thumb stick and very gently take it off.
  19. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 19 中的图像 1,2 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 19 中的图像 2,2
    • The wire that plugs into the actual remote needs to be pulled apart from the whole nunchuk.
    • The wires can be by its self without the plastic controller housing.
  20. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 20 中的图像 1,2 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 20 中的图像 2,2
    • Flip the wires over and remove the shoulder buttons (white plastic).
    • It'll be easier to slide the other piece out to so make sure to gently slide it out.
  21. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 21 中的图像 1,2 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 21 中的图像 2,2
    • Then remove the plastic that connects the sensor and the shoulder buttons.
  22. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 22 中的图像 1,3 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 22 中的图像 2,3 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 22 中的图像 3,3
    • Now start to attach all of the pieces back starting with the hard plastic first.
    • Make sure not to force the sensor in the spot and slide it upwards.
    • The shoulder buttons are easy to put in but don't push it.
    • Example of my partner.
  23. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 23 中的图像 1,2 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 23 中的图像 2,2
    • Be careful when putting the wires back in because they are easy to fall out.
  24. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 24 中的图像 1,2 Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 24 中的图像 2,2
    • She then attaches the analog stick to get it going again.
  25. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: 步骤 25 中的图像 1,1
    • Lastly she easily popped the top back on and screwed the bottom to back on and got it to work as it used to.
结论
23等其他人完成本指南。
Linda Bowers
于10/24/16注册
859 声望
撰写一个指南
6条评论
Great guide! I took one of my remotes apart some years ago. Now, with fresh tri-wing driver in hand, I am ready to reassemble the thing. Problem: where to solder the green ground? It currently is fused to the nunchuk connector housing, but where does the other end go??? Wish I'd noted that, back then
K. Lehnert - 回复
Very accurate guide! I was able to clear debris between the buttons with ease.
Aiden - 回复
Hello do you have tutorials for unassembly nunchuck's connector please?
Patrick WAI KHAI SONE - 回复
Thank you ! My A button registered the click half the time : turns out it had corrosion, now it works like a charm !
CreaZyp! - 回复
I want to take the springs off the wii Remotes Back. The ones that are still in the back during Step 10.
Emmanuel Ladejobi - 回复
添加评论
浏览统计数据:
过去 24 小时: 17
过去 7 天: 89
过去 30 天: 333
总计 41,238
