跳转到主内容
Nintendo Wii Motherboard Cover Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Nintendo Wii Motherboard Cover Replacement, Motherboard Cover: 步骤 1 中的图像 1,1
    • Use a pair of tweezers to lift the fan connector up and out of its socket on the logic board.
    • Be sure your tweezers are clamped down on the fan connector, not the socket on the motherboard.
  2. Nintendo Wii Motherboard Cover Replacement: 步骤 2 中的图像 1,2 Nintendo Wii Motherboard Cover Replacement: 步骤 2 中的图像 2,2
    • Remove the two 10 mm Phillips screws securing the fan to the fan shroud.
    • Remove the fan from the Wii.
  3. Nintendo Wii Motherboard Cover Replacement: 步骤 3 中的图像 1,2 Nintendo Wii Motherboard Cover Replacement: 步骤 3 中的图像 2,2
    • Use the tip of a spudger or another fine-pointed tool to carefully pry one of the black plastic retaining fingers attached to the fan shroud away from the Wi-Fi antenna board.
    • Lift the Wi-Fi antenna out of the fan shroud.
  4. Nintendo Wii Motherboard Cover Replacement: 步骤 4 中的图像 1,1
    • Remove the single 10 mm Phillips screw securing the second Wi-Fi antenna to the top of the fan shroud.
  5. Nintendo Wii Motherboard Cover Replacement: 步骤 5 中的图像 1,1
    • Remove the two pieces of tape securing the second Wi-Fi antenna cable to the plastic bracket near the heat sink.
  6. Nintendo Wii Motherboard Cover Replacement: 步骤 6 中的图像 1,1
    • Carefully de-route both antennas from the frame of the Wii and lay them aside.
  7. Nintendo Wii Motherboard Cover Replacement: 步骤 7 中的图像 1,2 Nintendo Wii Motherboard Cover Replacement: 步骤 7 中的图像 2,2
    • Remove the three 10 mm Phillips screws securing the fan shroud to the Wii.
    • Lift the fan shroud off the heat sink and remove it from the Wii.
  8. Nintendo Wii Motherboard Cover Replacement: 步骤 8 中的图像 1,3 Nintendo Wii Motherboard Cover Replacement: 步骤 8 中的图像 2,3 Nintendo Wii Motherboard Cover Replacement: 步骤 8 中的图像 3,3
    • Remove the following six screws securing the EMI fingers to the bottom panel:
    • Four 7 mm Phillips screws
    • Two 11.3 mm Phillips screws
    • Remove both sets of EMI fingers from the Wii.
  9. Nintendo Wii Motherboard Cover Replacement: 步骤 9 中的图像 1,2 Nintendo Wii Motherboard Cover Replacement: 步骤 9 中的图像 2,2
    • Remove the following three screws:
    • One 7 mm Phillips screw
    • Two 10 mm Phillips screws
    • Lift the bracket out of the Wii.
  10. Nintendo Wii Motherboard Cover Replacement: 步骤 10 中的图像 1,3 Nintendo Wii Motherboard Cover Replacement: 步骤 10 中的图像 2,3 Nintendo Wii Motherboard Cover Replacement: 步骤 10 中的图像 3,3
    • Remove the three 10 mm Phillips screws securing the black bracket to the bottom panel near the front of the Wii.
    • Slightly lift the bracket and use your other hand to pull the retaining clip away from where the Wi-Fi antennas enter the motherboard sheild.
    • Remove the bracket from the Wii.
    • Be sure not to lose the small square nut loosely held by the black plastic bracket.
  11. Nintendo Wii Motherboard Cover Replacement: 步骤 11 中的图像 1,1
    • Remove the nine remaining 7 mm Phillips screws securing the motherboard cover to the bottom panel.
  12. Nintendo Wii Motherboard Cover Replacement: 步骤 12 中的图像 1,1
    • Carefully lift the motherboard cover off the motherboard, minding any cables that may get caught.
    • On some models, a thermal pad for the wireless chip is attached to the underside of the motherboard cover. Be sure to replace it when reassembling.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 974
