跳转到主内容
加入维修社区 - 创建账户
Nintendo Wii Drive Board Fuse Replacement
你所需要的
  1. Nintendo Wii Drive Board Fuse Replacement, Faceplate: 步骤 1 中的图像 1,2 Nintendo Wii Drive Board Fuse Replacement, Faceplate: 步骤 1 中的图像 2,2
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
    添加评论
  2. Nintendo Wii Drive Board Fuse Replacement: 步骤 2 中的图像 1,1
    • Remove the two 8.3 mm Tri-Point screws hidden under the covers you just removed.
    添加评论
  3. Nintendo Wii Drive Board Fuse Replacement: 步骤 3 中的图像 1,1
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
    添加评论
  4. Nintendo Wii Drive Board Fuse Replacement: 步骤 4 中的图像 1,1
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
    添加评论
  5. Nintendo Wii Drive Board Fuse Replacement: 步骤 5 中的图像 1,1
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
    添加评论
  6. Nintendo Wii Drive Board Fuse Replacement: 步骤 6 中的图像 1,2 Nintendo Wii Drive Board Fuse Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
    添加评论
  7. Nintendo Wii Drive Board Fuse Replacement, Outer Case: 步骤 7 中的图像 1,3 Nintendo Wii Drive Board Fuse Replacement, Outer Case: 步骤 7 中的图像 2,3 Nintendo Wii Drive Board Fuse Replacement, Outer Case: 步骤 7 中的图像 3,3
    • Open the controller port cover until it is perpendicular to the black controller port bezel.
    • Pull the controller port cover straight up to release it from the outer case.
    • Repeat this procedure for the memory card port cover.
    添加评论
  8. Nintendo Wii Drive Board Fuse Replacement: 步骤 8 中的图像 1,2 Nintendo Wii Drive Board Fuse Replacement: 步骤 8 中的图像 2,2
    • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
    • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
    添加评论
  9. Nintendo Wii Drive Board Fuse Replacement: 步骤 9 中的图像 1,1
    • Remove the two 5 mm Phillips screws above the controller ports.
    添加评论
  10. Nintendo Wii Drive Board Fuse Replacement: 步骤 10 中的图像 1,1
    • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
    添加评论
  11. Nintendo Wii Drive Board Fuse Replacement: 步骤 11 中的图像 1,1
    • Remove the following screws:
    • Two 5 mm Phillips screws
    • One 8.2 mm Tri-Point screw
    添加评论
  12. Nintendo Wii Drive Board Fuse Replacement: 步骤 12 中的图像 1,1
    • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
    询问修复机器人
    添加评论
  13. Nintendo Wii Drive Board Fuse Replacement: 步骤 13 中的图像 1,1
    在这个步骤中使用的工具:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • Remove the two 8.2 mm Tri-Point screws hidden under the feet you just removed.
    • You may use a 4 mm hex nut driver to extend your bit into the recesses and reach the screws.
    添加评论
  14. Nintendo Wii Drive Board Fuse Replacement: 步骤 14 中的图像 1,1
    • Lift the outer case straight up off the body of the Wii.
    添加评论
  15. Nintendo Wii Drive Board Fuse Replacement, DVD Drive: 步骤 15 中的图像 1,2 Nintendo Wii Drive Board Fuse Replacement, DVD Drive: 步骤 15 中的图像 2,2
    • Remove the small Phillips screw securing the battery door to the bottom panel.
    • This screw is captive to the battery door.
    • Pull the battery door out of the Wii.
    • The system time will be reset once you remove the battery door.
    • This is a good time to change the CR2032 battery if it hasn't been changed recently.
    添加评论
  16. Nintendo Wii Drive Board Fuse Replacement: 步骤 16 中的图像 1,1
    • Remove the 8.2 mm Tri-Point screw that was hidden beneath the battery door.
    添加评论
  17. Nintendo Wii Drive Board Fuse Replacement: 步骤 17 中的图像 1,1
    • Remove the two 8.2 mm Tri-Point screws securing the DVD drive shield near the controller ports.
    添加评论
  18. Nintendo Wii Drive Board Fuse Replacement: 步骤 18 中的图像 1,1
    • Be cautious as you remove the DVD shield, the edges are sharp and could cut you
    • Lift the DVD drive shield upward and remove it from the Wii.
    添加评论
  19. Nintendo Wii Drive Board Fuse Replacement: 步骤 19 中的图像 1,1
    • Remove the four 9 mm Phillips screws securing the DVD drive to the bottom panel.
    添加评论
  20. Nintendo Wii Drive Board Fuse Replacement: 步骤 20 中的图像 1,1
    • Lift the side of the DVD drive opposite the controller ports enough to access the cables on its bottom face.
    • Carefully pull the DVD drive power cable out from under the plastic shroud near the heat sink.
    添加评论
  21. Nintendo Wii Drive Board Fuse Replacement: 步骤 21 中的图像 1,1
    • Pull the DVD drive power cable away from its socket on the DVD drive.
    添加评论
  22. Nintendo Wii Drive Board Fuse Replacement: 步骤 22 中的图像 1,2 Nintendo Wii Drive Board Fuse Replacement: 步骤 22 中的图像 2,2
    • Use your fingernail to flip up the retaining flap on the DVD drive ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the DVD drive ribbon cable out of its socket.
    • Remove the DVD drive from the Wii.
    添加评论
  23. Nintendo Wii Drive Board Fuse Replacement, Drive Board Fuses: 步骤 23 中的图像 1,1
    • Measure across each fuse with a continuity meter.
    • If either fuse is open, you will need to replace it with an 0603 fuse; if one is not available, you can use a 0-ohm resistor or jumper wire for testing purposes.
    添加评论
结论
取消:我没有完成这个指南。
17等其他人完成本指南。
bushing
于04/23/10注册
10,502 声望
创作了13篇指南
4指南评论
Soldering jumpers on those fuses is easier said than done. The left-hand fuse follows the same trace all the way to the larger solder pad above, so don't worry about bridging. But it looks like there's a cap or diode along the trace of the right-hand fuse, so solder carefully! This worked great, and got my Wii drive back to spinning without spending $80 on a new drive.
Robert Allshouse - 回复 分享
If anyone could give specifications for the fuses needed, it would be very much appreciated... 0603 Fuses come in different amp ratings. I saw one person suggest elsewhere that after research he found that the ones used in this repair are 2A 0603 fuses, can anyone confirm this please before I get the wrong ones?
Thanks in advance,
James @ Retro Gaming Repair UK
Retro Gaming Repair - 回复 分享
I found a datasheet for littelfuse which labels the fuse as 2A. The datasheet can be found here
http://www.littelfuse.com/data/en/data_s....
Hope this helps.
Another tip for after you know the fuse is blown instead of removing the fuse and jumpering it add a little solder on both sides of the fuse then use a lead from a resister heating up the solder and push the lead from a resistor into it then do the same for the other side.
randyhenke - 回复 分享
this guide assumes you have one revision of the board....i have another revision and can only find one of the resistors
dude105tanki - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 45
过去 30 天: 247
总计 69,470
