简介
Replacing the bottom panel requires removal of every component inside the Wii.
你所需要的
Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
Open the controller port cover until it is perpendicular to the black controller port bezel.
Pull the controller port cover straight up to release it from the outer case.
Remove the small Phillips screw securing the battery door to the bottom panel.
Pull the battery door out of the Wii.
在这个步骤中使用的工具:Tweezers$4.99
Use a pair of tweezers to lift the fan connector up and out of its socket on the logic board.
Remove the four 11.3 mm Phillips screws securing the heat sink to the bottom panel.
Lift the motherboard assembly off the bottom panel, minding any cables that may get caught.
Bottom panel remains.
12等其他人完成本指南。
3指南评论
Hi, what is the purpose of the foam block in the last step? I've recently done a case mod, by my foam is not oriented correctly. Someone said this can cause issues. But I would like to know what exactly is its purpose.
### The small foam piece inside the Wii where the power cable plugs into serves as a cushion and helps to secure the connection.
* It helps to prevent any unwanted movement or vibrations that could potentially disrupt the power supply to the Wii console.
* The foam piece may act as a barrier to reduce the risk of any electrical interference or short circuits that could occur when plugging or unplugging the power cable.
* It's a simple but useful design element to ensure a stable and reliable power connection for the Wii console.
