跳转到主内容
加入维修社区 - 创建账户
Nintendo WaveBird Wireless Controller Front Panel Replacement
你所需要的
  1. Nintendo WaveBird Wireless Controller Front Panel Replacement, Batteries: 步骤 1 中的图像 1,2 Nintendo WaveBird Wireless Controller Front Panel Replacement, Batteries: 步骤 1 中的图像 2,2
    • Pull down on the battery cover release lever and pull back to remove the cover.
  2. Nintendo WaveBird Wireless Controller Front Panel Replacement: 步骤 2 中的图像 1,1
    • Remove both batteries from the device.
  3. Nintendo WaveBird Wireless Controller Front Panel Replacement, Front Panel: 步骤 3 中的图像 1,2 Nintendo WaveBird Wireless Controller Front Panel Replacement, Front Panel: 步骤 3 中的图像 2,2
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
  4. Nintendo WaveBird Wireless Controller Front Panel Replacement: 步骤 4 中的图像 1,2 Nintendo WaveBird Wireless Controller Front Panel Replacement: 步骤 4 中的图像 2,2
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
结论
3等其他人完成本指南。
JT Gryder
于04/12/13注册
114 声望
撰写一个指南
团队
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013 的会员
CPSU-AMIDO-S13S10G40
4 名成员
创作了37篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 1,785
