跳转到主内容
Nintendo Switch Shield Plate Replacement
你所需要的
  1. Nintendo Switch Shield Plate Replacement, Release the Joy Con controller locking tabs: 步骤 1 中的图像 1,3 Nintendo Switch Shield Plate Replacement, Release the Joy Con controller locking tabs: 步骤 1 中的图像 2,3 Nintendo Switch Shield Plate Replacement, Release the Joy Con controller locking tabs: 步骤 1 中的图像 3,3
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch Shield Plate Replacement, Remove the Joy Con controllers: 步骤 2 中的图像 1,3 Nintendo Switch Shield Plate Replacement, Remove the Joy Con controllers: 步骤 2 中的图像 2,3 Nintendo Switch Shield Plate Replacement, Remove the Joy Con controllers: 步骤 2 中的图像 3,3
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch Shield Plate Replacement, Remove the back-side screws: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
  4. Nintendo Switch Shield Plate Replacement, Remove the top and bottom screws: 步骤 4 中的图像 1,2 Nintendo Switch Shield Plate Replacement, Remove the top and bottom screws: 步骤 4 中的图像 2,2
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try another JIS 000 or PH 000 driver if the screws won't come out.
  5. Nintendo Switch Shield Plate Replacement: 步骤 5 中的图像 1,2 Nintendo Switch Shield Plate Replacement: 步骤 5 中的图像 2,2
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
  6. Nintendo Switch Shield Plate Replacement: 步骤 6 中的图像 1,2 Nintendo Switch Shield Plate Replacement: 步骤 6 中的图像 2,2
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  7. Nintendo Switch Shield Plate Replacement: 步骤 7 中的图像 1,1
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the 1.6 mm screw in the kickstand well.
    • Close the kickstand.
  8. Nintendo Switch Shield Plate Replacement: 步骤 8 中的图像 1,3 Nintendo Switch Shield Plate Replacement: 步骤 8 中的图像 2,3 Nintendo Switch Shield Plate Replacement: 步骤 8 中的图像 3,3
    • Open the game card cartridge flap.
    • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
    • Lift the rear panel up from the bottom of the device and remove it.
  9. Nintendo Switch Shield Plate Replacement, Remove the microSD card reader: 步骤 9 中的图像 1,1
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
  10. Nintendo Switch Shield Plate Replacement: 步骤 10 中的图像 1,2 Nintendo Switch Shield Plate Replacement: 步骤 10 中的图像 2,2
    • Use your fingers or a pair of tweezers to lift the microSD card reader straight up from the device to disconnect and remove it.
    • During reassembly, make sure the press connector underneath the foam pad is firmly connected to the motherboard. It may help to remove the foam pad before reinstalling the card reader.
  11. Nintendo Switch Shield Plate Replacement, Shield Plate: 步骤 11 中的图像 1,1
    • Remove the six 3.1mm JIS #000 screws from the shield plate.
  12. Nintendo Switch Shield Plate Replacement: 步骤 12 中的图像 1,3 Nintendo Switch Shield Plate Replacement: 步骤 12 中的图像 2,3 Nintendo Switch Shield Plate Replacement: 步骤 12 中的图像 3,3
    • Remove the shield plate from the device.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. Use our thermal paste guide to remove the old thermal compound and replace it with an appropriate, thick compound such as K5 Pro.
结论
21等其他人完成本指南。
Blake Klein
于01/29/17注册
70,531 声望
创作了50篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 36
过去 30 天: 267
总计 16,063
