简介
This guide aims to walk you through the steps required in replacing the face buttons on the right Joy-Con for the Nintendo Switch. This repair is slightly more difficult than the left Joy-Con as there are more components built into the right than there are in the left. Additional components to be aware of include the Infrared Sensor, Bluetooth Antenna, and NFC Antenna.
Use a Tri-wing Y00 screwdriver to remove the four 5mm screws holding the back panel in place.
To reassemble your device, follow these instructions in reverse order. Be sure not to screw the motherboard in too tight as this may affect the responsiveness of the buttons. Always apply even pressure to screws when reinstalling the components; one side should not be tighter than the other.
5等其他人完成本指南。
一条评论
Thank you. The guide from the company I bought the replacement buttons from on Amazon was extremely lacking. This was on point.
