简介
Follow this guide to replace the power and volume button board inside of a Nintendo Switch gaming console.
你所需要的
Press and hold down the small round button on the back of the Joy Con controller.
While you hold down the button, slide the controller upward.
Continue sliding the Joy Con upward until it's completely removed from the console.
在这个步骤中使用的工具:Magnetic Project Mat$19.95
Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the rear panel:
One 2.5 mm-long screw on the top edge of the device
Two 2.5 mm-long screws on the bottom edge of the device
Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the six 3 mm screws securing the shield plate to the device.
Insert a spudger underneath the shield plate along the edge of the device.
Pry up to lift the shield plate and remove it from the device.
You can reuse the pink thermal compound if you're careful. Keep the compound clean and make sure it makes solid contact between the heat sink and the shield during reassembly.
If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as K5 Pro, during reassembly.
Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
Carefully peel the two foam pieces stuck over both the heatsink and the fan away from the fan.
Insert the point of a spudger underneath the part of the foam that isn't stuck against anything,
Press the top of the foam with your finger to hold it in place.
Roll the spudger tip underneath the foam all the way to the other end of the foam to release it.
Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the fan cable ZIF connector.
Use a spudger to flip up the small black locking flap on the power/volume ribbon cable ZIF connector.
14等其他人完成本指南。
7条评论
Great guide. Just repaired my daughters Switch by replacing power button.
I replaced the cable and still have the same issue, volume up button don't work and volume down is volume up, and it's always kn
Hi, did you manage to fix it? I have the exact issue
I changed the cable and it works.
Thanks
Great guide. There were a couple of steps I found missing, but the rest of the guide had very similar steps, so just applying the same logic to the mini-boards I had to pull worked perfectly. This guide saved me from having to buy a new switch or pay almost the price of a new one to have it repaired!
