跳转到主内容
加入维修社区 - 创建账户
Nintendo Switch Battery Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
视频概述
  1. Nintendo Switch Battery Replacement, Battery: 步骤 1 中的图像 1,2 Nintendo Switch Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Insert the pointed end of a spudger underneath the white connector and pry upwards to disconnect the battery from the motherboard.
  2. Nintendo Switch Battery Replacement: 步骤 2 中的图像 1,2 Nintendo Switch Battery Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    iFixit Adhesive Remover
    $19.99
    • The Nintendo Switch battery is glued in place. For best results, we recommend applying some high-concentration (90% or greater) isopropyl alcohol or our Adhesive Remover as shown in this step before attempting to remove the battery.
    • Apply a small amount of adhesive remover or isopropyl alcohol (approximately 1 ml) evenly along one edge of the battery cell.
    • Tilt the switch so the liquid solvent spreads underneath the battery.
    • Wait 2-3 minutes for the solvent to break down the adhesive underneath the battery before you proceed to the next step.
  3. Nintendo Switch Battery Replacement: 步骤 3 中的图像 1,2 Nintendo Switch Battery Replacement: 步骤 3 中的图像 2,2
    • Use a pry tool to lever the battery out.
    • Don't use excessive force. A damaged lithium-ion battery can leak toxic chemicals and/or catch fire. If the battery doesn't lever out fairly easily, apply a little more solvent and try again.
  4. Nintendo Switch Battery Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $8.95
    • Remove the battery from the Switch console.
    • Don't re-use the battery once it's removed.
    • Use strips of double-sided adhesive tape to secure the new battery.
结论
Blake Klein
于01/29/17注册
74,013 声望
创作了50篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 68
