跳转到主内容
Nintendo Super Famicom SHVC-001 Controller Port Board Replacement
你所需要的
  1. Nintendo Super Famicom SHVC-001 Controller Port Board Replacement, Upper Case: 步骤 1 中的图像 1,1
    • Remove the six 13.5 mm screws on the lower case with a 4.5 mm Gamebit screwdriver.
  2. Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: 步骤 2 中的图像 1,2 Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: 步骤 2 中的图像 2,2
    • Flip the Famicom over and set it down.
    • Lift off the upper case.
  3. Nintendo Super Famicom SHVC-001 Controller Port Board Replacement, Controller Port Board: 步骤 3 中的图像 1,2 Nintendo Super Famicom SHVC-001 Controller Port Board Replacement, Controller Port Board: 步骤 3 中的图像 2,2
    • Carefully disconnect the ribbon cable that is attached to the controller board and the main board.
  4. Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: 步骤 4 中的图像 1,1
    • Lift the controller port board directly up and out of the chassis.
    • If your new controller port board does not come with a ribbon cable, you will also need to replace that.
  5. Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: 步骤 5 中的图像 1,3 Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: 步骤 5 中的图像 2,3 Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: 步骤 5 中的图像 3,3
    • The next bullet demonstrates how to replace your ribbon cable.
    • Disconnect and remove the old cable and replace it with a new 1.25 mm ribbon cable.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 21
总计 66
