本指南有最近更改,您可查看未经巡查的最新版本。
简介
Removing the top case will allow you access to the GameCube's internal parts.
你所需要的
Turn over the Gamecube so that the bottom side is facing up.
Locate the four screws (circled in red) on each corner of the device. Then, use a 4.5 mm Gamebit screwdriver to remove all four screws.
13等其他人完成本指南。
一条评论
Can you do a more in-depth version of the top cover? I had to clean each piece and need help figuring out where all the pieces go. Thanks
JJ Jackson - 回复
