跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Nintendo GameCube Optical Drive Assembly Replacement
你所需要的
  1. Nintendo GameCube Optical Drive Assembly Replacement, Top Case: 步骤 1 中的图像 1,3 Nintendo GameCube Optical Drive Assembly Replacement, Top Case: 步骤 1 中的图像 2,3 Nintendo GameCube Optical Drive Assembly Replacement, Top Case: 步骤 1 中的图像 3,3
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
  2. Nintendo GameCube Optical Drive Assembly Replacement: 步骤 2 中的图像 1,3 Nintendo GameCube Optical Drive Assembly Replacement: 步骤 2 中的图像 2,3 Nintendo GameCube Optical Drive Assembly Replacement: 步骤 2 中的图像 3,3
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
  3. Nintendo GameCube Optical Drive Assembly Replacement, Removing the back panel: 步骤 3 中的图像 1,1
    • Gently press down on the clips located on either side of the back panel.
    • Carefully remove the back panel from the GameCube.
  4. Nintendo GameCube Optical Drive Assembly Replacement: 步骤 4 中的图像 1,1
    • Unclip the controller ports at the front of the unit.
    • A ribbon cable (outlined in orange) is still attached to the unit. Do not disconnect this cable.
    • Controller ports are where the controllers plug into the game console, and are a half circular shape.
  5. Nintendo GameCube Optical Drive Assembly Replacement, Separate the casing: 步骤 5 中的图像 1,2 Nintendo GameCube Optical Drive Assembly Replacement, Separate the casing: 步骤 5 中的图像 2,2
    • Use a Phillips #2 screwdriver to remove the two screws on the back of the control port.
    • Carefully separate the gray outer casing of the control port and the circuit board.
  6. Nintendo GameCube Optical Drive Assembly Replacement, Remove Nintendo GameCube Optical Drive Assembly: 步骤 6 中的图像 1,2 Nintendo GameCube Optical Drive Assembly Replacement, Remove Nintendo GameCube Optical Drive Assembly: 步骤 6 中的图像 2,2
    • The left side of the unit contains the cooling fan and its housing.
    • Carefully remove the two screws attaching the cooling fan housing to the unit.
    • Do not detach the red and black cooling fan wire from the main unit. Boxed in orange.
  7. Nintendo GameCube Optical Drive Assembly Replacement: 步骤 7 中的图像 1,2 Nintendo GameCube Optical Drive Assembly Replacement: 步骤 7 中的图像 2,2
    • Remove the four Phillips #1 screws retaining the ground springs.
    • Carefully remove the ground springs from the main unit.
  8. Nintendo GameCube Optical Drive Assembly Replacement: 步骤 8 中的图像 1,2 Nintendo GameCube Optical Drive Assembly Replacement: 步骤 8 中的图像 2,2
    • The optical drive is secured to a metal plate.
    • Using a Phillips #2 screwdriver, unscrew the twelve screws that are around the outer edge of the optical drive.
  9. Nintendo GameCube Optical Drive Assembly Replacement, Remove the assembly: 步骤 9 中的图像 1,3 Nintendo GameCube Optical Drive Assembly Replacement, Remove the assembly: 步骤 9 中的图像 2,3 Nintendo GameCube Optical Drive Assembly Replacement, Remove the assembly: 步骤 9 中的图像 3,3
    • Carefully separate the optical drive assembly from the rest of the GameCube unit.
    • The optical drive assembly is secured to the motherboard underneath by a slot; some force may be required to carefully free the assembly.
    • The metal plate and the actual optical drive will remain attached.
  10. Nintendo GameCube Optical Drive Assembly Replacement, Optical Drive Assembly: 步骤 10 中的图像 1,3 Nintendo GameCube Optical Drive Assembly Replacement, Optical Drive Assembly: 步骤 10 中的图像 2,3 Nintendo GameCube Optical Drive Assembly Replacement, Optical Drive Assembly: 步骤 10 中的图像 3,3
    • At this point, your optical drive assembly should be separated from your GameCube (picture 1).
    • Flip the optical drive assembly upside down
    • Shown in picture 2, remove the 6 Phillips #1 screws with a philips screwdriver.
    • Once the screws are removed, gently lift and remove the metal plate (shown in picture 3).
    • Be careful not to disturb the brown ribbon cable (highlighted in the yellow).
  11. Nintendo GameCube Optical Drive Assembly Replacement: 步骤 11 中的图像 1,3 Nintendo GameCube Optical Drive Assembly Replacement: 步骤 11 中的图像 2,3 Nintendo GameCube Optical Drive Assembly Replacement: 步骤 11 中的图像 3,3
    • Remove the blue wire by gently pulling.
    • Disconnect the Brown cable. This is done by gently pulling the black tab away from the white plastic. This will loosen the tension on the brown cable allowing it to gently be slid away from the tab.
    • Shown in the third picture, remove the 4 Phillips #1 screws connecting the circuit board to the optical drive assembly.
    • The fourth screw is located behind the screwdriver in the third picture (highlighted in the orange circle).
  12. Nintendo GameCube Optical Drive Assembly Replacement: 步骤 12 中的图像 1,3 Nintendo GameCube Optical Drive Assembly Replacement: 步骤 12 中的图像 2,3 Nintendo GameCube Optical Drive Assembly Replacement: 步骤 12 中的图像 3,3
    • Gently remove the circuit board (the large green square) as shown in the three pictures.
    • DO NOT SEPARATE the red wire or the white ribbon cable connecting the circuit board to the metal plate.
    • Red Wire
    • White ribbon Cable
  13. Nintendo GameCube Optical Drive Assembly Replacement: 步骤 13 中的图像 1,3 Nintendo GameCube Optical Drive Assembly Replacement: 步骤 13 中的图像 2,3 Nintendo GameCube Optical Drive Assembly Replacement: 步骤 13 中的图像 3,3
    • Use a flathead screwdriver to carefully release the four plastic clips holding the drive assembly together.
    • The last clip can be rather hard to find. Carefully use a screwdriver as leverage to unscrew and release the last clip, which is highlighted in blue (Picture 3).
  14. Nintendo GameCube Optical Drive Assembly Replacement: 步骤 14 中的图像 1,3 Nintendo GameCube Optical Drive Assembly Replacement: 步骤 14 中的图像 2,3 Nintendo GameCube Optical Drive Assembly Replacement: 步骤 14 中的图像 3,3
    • Gently lift the metal plate off of the drive assembly (shown in the first picture).
    • Be careful not to sever the red wire or the white ribbon cable still attached to the two halves of the drive assembly.
    • Then flip the two halves of the drive assembly upside down as shown in the third picture.
  15. Nintendo GameCube Optical Drive Assembly Replacement: 步骤 15 中的图像 1,3 Nintendo GameCube Optical Drive Assembly Replacement: 步骤 15 中的图像 2,3 Nintendo GameCube Optical Drive Assembly Replacement: 步骤 15 中的图像 3,3
    • Use a flathead screwdriver to release the two clips located on the back half of the drive assembly.
    • The final clip doesn't need to be released; the top half of the drive assembly will slide away from the lower half.
    • Finish removing the top half of the drive assembly from the base.
    • Be careful not to detach the red wire or the white ribbon cable still attached.
  16. Nintendo GameCube Optical Drive Assembly Replacement: 步骤 16 中的图像 1,2 Nintendo GameCube Optical Drive Assembly Replacement: 步骤 16 中的图像 2,2
    • Once the top half of the drive assembly is detached, turn it upside down.
    • Using a philips screwdriver, carefully remove the 3 final screws located near the bars of the lens assembly.
    • Once the the three final screws are removed, the lens assembly can be extracted (as shown in the second picture).
结论
20等其他人完成本指南。
mwbisson
于11/05/09注册
1,038 声望
创作了3篇指南
团队
Cal Poly, Team 6-2, Maness Fall 2009 Cal Poly, Team 6-2, Maness Fall 2009 的会员
CPSU-MANESS-F09S6G2
4 名成员
创作了44篇指南
5条评论
What type of optical drive could I use to replace the one in said GameCube once I've broken it down?
Bob Marotta - 回复
Did you ever find out, Bob?
Lee Martin -
I found OEM parts (removed from other Game Cubes) available on Ebay. Just ordered the part for about $16.
erin clark - 回复
Good walkthrough. My 8 year old completed this repair with minimal help from me. Thanks!
erin clark - 回复
As a tech writer I just wanted to say our step by step instructions are spot on. Great Job
Jim Canfield - 回复
添加评论
浏览统计数据:
过去 24 小时: 21
过去 7 天: 159
过去 30 天: 747
总计 57,748
