当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Carefully separate the optical drive assembly from the rest of the GameCube unit.
The optical drive assembly is secured to the motherboard underneath by a slot; some force may be required to carefully free the assembly.
The metal plate and the actual optical drive will remain attached.
12等其他人完成本指南。
3条评论
What happens if you disconnect that cable (localizated on Step 4)?
Santi12008 - 回复
Its soldered to the front-board and the connector is on the main-board under the disc assembly, trying to remove it will break it.
I have been having trouble with my cube shorting out when I insert a memory card into slot A. What is the best way to get at it see if this is the case, and what should I be looking for?
Many thanks
