跳转到主内容
加入维修社区 - 创建账户
Nintendo GameCube Motherboard Replacement
你所需要的
    1. Nintendo GameCube Motherboard Replacement, Top Case: 步骤 1 中的图像 1,3 Nintendo GameCube Motherboard Replacement, Top Case: 步骤 1 中的图像 2,3 Nintendo GameCube Motherboard Replacement, Top Case: 步骤 1 中的图像 3,3
      • Turn over the Gamecube so that the bottom side is facing up.
      • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
      询问修复机器人
      添加评论
    2. Nintendo GameCube Motherboard Replacement: 步骤 2 中的图像 1,3 Nintendo GameCube Motherboard Replacement: 步骤 2 中的图像 2,3 Nintendo GameCube Motherboard Replacement: 步骤 2 中的图像 3,3
      • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
      • Move the GameCube so that the inside is facing upwards.
      添加评论
    1. Nintendo GameCube Motherboard Replacement, Removing the back panel: 步骤 3 中的图像 1,1
      • Gently press down on the clips located on either side of the back panel.
      • Carefully remove the back panel from the GameCube.
      添加评论
    2. Nintendo GameCube Motherboard Replacement: 步骤 4 中的图像 1,1
      • Unclip the controller ports at the front of the unit.
      • A ribbon cable (outlined in orange) is still attached to the unit. Do not disconnect this cable.
      • Controller ports are where the controllers plug into the game console, and are a half circular shape.
      添加评论
    3. Nintendo GameCube Motherboard Replacement, Separate the casing: 步骤 5 中的图像 1,2 Nintendo GameCube Motherboard Replacement, Separate the casing: 步骤 5 中的图像 2,2
      • This step may not be necessary depending on your end goal
      • Use a Phillips #2 screwdriver to remove the two screws on the back of the control port.
      • Carefully separate the gray outer casing of the control port and the circuit board.
      添加评论
    1. Nintendo GameCube Motherboard Replacement, Remove Nintendo GameCube Optical Drive Assembly: 步骤 6 中的图像 1,2 Nintendo GameCube Motherboard Replacement, Remove Nintendo GameCube Optical Drive Assembly: 步骤 6 中的图像 2,2
      • The left side of the unit contains the cooling fan and its housing.
      • Carefully remove the two screws attaching the cooling fan housing to the unit.
      • Do not detach the red and black cooling fan wire from the main unit. Boxed in orange.
      添加评论
    2. Nintendo GameCube Motherboard Replacement: 步骤 7 中的图像 1,2 Nintendo GameCube Motherboard Replacement: 步骤 7 中的图像 2,2
      • Remove the four Phillips #1 screws retaining the ground springs.
      • Carefully remove the ground springs from the main unit.
      询问修复机器人
      添加评论
    3. Nintendo GameCube Motherboard Replacement: 步骤 8 中的图像 1,2 Nintendo GameCube Motherboard Replacement: 步骤 8 中的图像 2,2
      • The optical drive is secured to a metal plate.
      • Using a Phillips #2 screwdriver, unscrew the twelve screws that are around the outer edge of the optical drive.
      添加评论
    4. Nintendo GameCube Motherboard Replacement, Remove the assembly: 步骤 9 中的图像 1,3 Nintendo GameCube Motherboard Replacement, Remove the assembly: 步骤 9 中的图像 2,3 Nintendo GameCube Motherboard Replacement, Remove the assembly: 步骤 9 中的图像 3,3
      • Carefully separate the optical drive assembly from the rest of the GameCube unit.
      • The optical drive assembly is secured to the motherboard underneath by a slot; some force may be required to carefully free the assembly.
      • The metal plate and the actual optical drive will remain attached.
      询问修复机器人
      添加评论
    1. Nintendo GameCube Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,2 Nintendo GameCube Motherboard Replacement, Motherboard: 步骤 10 中的图像 2,2
      • With the Optical Drive Assembly removed, your GameCube should now look like this.
      • Remove the 6 screws (circled in orange) on the heat sink using a #1 Phillips screwdriver.
      询问修复机器人
      添加评论
    2. Nintendo GameCube Motherboard Replacement: 步骤 11 中的图像 1,2 Nintendo GameCube Motherboard Replacement: 步骤 11 中的图像 2,2
      • Gently lift the motherboard from base (as shown in second picture).
      询问修复机器人
      添加评论
    3. Nintendo GameCube Motherboard Replacement: 步骤 12 中的图像 1,2 Nintendo GameCube Motherboard Replacement: 步骤 12 中的图像 2,2
      • Carefully disconnect the ribbon cable connecting the motherboard with the front panel.
      • At this point you can replace the old motherboard with a new one and enjoy your now-functional GameCube!
      添加评论
结论
取消:我没有完成这个指南。
16等其他人完成本指南。
mwbisson
于11/05/09注册
1,161 声望
创作了3篇指南
团队
Cal Poly, Team 6-2, Maness Fall 2009 Cal Poly, Team 6-2, Maness Fall 2009 的会员
CPSU-MANESS-F09S6G2
4 名成员
创作了53篇指南
3指南评论
What happens if you disconnect that cable (localizated on Step 4)?
Santi12008 - 回复 分享
Its soldered to the front-board and the connector is on the main-board under the disc assembly, trying to remove it will break it.
Joseph Lalone - 回复 分享
I have been having trouble with my cube shorting out when I insert a memory card into slot A. What is the best way to get at it see if this is the case, and what should I be looking for?
Many thanks
farrell dann - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 58
过去 30 天: 264
总计 36,873
