跳转到主内容
Nintendo GameCube Controller Triggers Replacement
你所需要的
  1. Nintendo GameCube Controller Triggers Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Nintendo GameCube Controller Triggers Replacement: 步骤 2 中的图像 1,1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
  3. Nintendo GameCube Controller Triggers Replacement, Z Button: 步骤 3 中的图像 1,2 Nintendo GameCube Controller Triggers Replacement, Z Button: 步骤 3 中的图像 2,2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
  4. Nintendo GameCube Controller Triggers Replacement, Circuit Board: 步骤 4 中的图像 1,1
    • Carefully unhook the cable that is looped around the peg.
  5. Nintendo GameCube Controller Triggers Replacement: 步骤 5 中的图像 1,1
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
  6. Nintendo GameCube Controller Triggers Replacement, Triggers: 步骤 6 中的图像 1,1
    • Remove the two 8.9mm Phillips Head #0 screws.
  7. Nintendo GameCube Controller Triggers Replacement: 步骤 7 中的图像 1,1
    • Remove black cover.
  8. Nintendo GameCube Controller Triggers Replacement: 步骤 8 中的图像 1,3 Nintendo GameCube Controller Triggers Replacement: 步骤 8 中的图像 2,3 Nintendo GameCube Controller Triggers Replacement: 步骤 8 中的图像 3,3
    • To remove the trigger assembly, depress the trigger with your index finger as if you are using the controller normally.
    • Hold the grey square bracket onside of the controller with your thumb.
    • Keep your fingers in the same place while rotating upwards towards you to remove trigger assembly.
  9. Nintendo GameCube Controller Triggers Replacement: 步骤 9 中的图像 1,1
    • Pull the metal clip from the trigger.
结论
In order to remove the other trigger, simply repeat Steps 6 through Step 9 on the right side.
11等其他人完成本指南。
Sean Michel
于01/14/13注册
2,600 声望
创作了8篇指南
团队
Cal Poly, Team 19-44, Regan Winter 2013 Cal Poly, Team 19-44, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G44
4 名成员
创作了32篇指南
3指南评论
Don't forget to aline the trigger slider holes and the slider pins on the board when putting it all back together.
buttpug - 回复
Hallo ich habe da mal eine Frage. Ist es möglich die Empfindlichkeit der Trigger zu beeinflussen ? Leider reagieren sie erst sehr spät da mann den Knopf sehr weit hereindrücken muss.
danke schon mal
Otti
Ottitrotti - 回复
The trigger slider hole doesn’t sit well on the slider pins any suggestions ?
cHiLLz747 - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 34
过去 30 天: 144
总计 29,409
