跳转到主内容
Nintendo GameCube Controller Circuit Board Replacement
你所需要的
  1. Nintendo GameCube Controller Circuit Board Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Nintendo GameCube Controller Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
  3. Nintendo GameCube Controller Circuit Board Replacement, Z Button: 步骤 3 中的图像 1,2 Nintendo GameCube Controller Circuit Board Replacement, Z Button: 步骤 3 中的图像 2,2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
  4. Nintendo GameCube Controller Circuit Board Replacement, Circuit Board: 步骤 4 中的图像 1,1
    • Carefully unhook the cable that is looped around the peg.
  5. Nintendo GameCube Controller Circuit Board Replacement: 步骤 5 中的图像 1,1
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
结论
5等其他人完成本指南。
Sean Michel
于01/14/13注册
2,600 声望
创作了8篇指南
团队
Cal Poly, Team 19-44, Regan Winter 2013 Cal Poly, Team 19-44, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G44
4 名成员
创作了32篇指南
2指南评论
Yeah this isn't very in-depth, I was hoping for a little more. I need to desolder and rewire the buttons to use for another project and I was hoping this might be a nice guide to help me do that... it's not.
Joshua Arcari - 回复
You left out the fun facts about every part and components so we know what the are and what they do. Well for me that would have been ideal as I'm fixing 2 controls that don't do anything and I already have to fix a game cube as I got 2 and one works and one don't lol
Don'tcare69 - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 29
过去 30 天: 107
总计 19,817
