当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
Lift the battery cover up and remove it from the device.
The screw will remain attached to the battery cover because of Nintendo's design.
Use your fingers or a plastic opening tool to remove the battery from the device.
Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
Lift the back cover off of the device.
Potential for device damage: These inner components are vulnerable to static electricity. Exercise caution when handling these next steps to prevent damaging the device.
Look out for the power switch that can fall out when taking the back cover off.
Lift the power switch cover away from the left side of the device using your fingers or tweezers.
取消:我没有完成这个指南。
17等其他人完成本指南。
与10其他贡献者
于01/11/13注册
1,924 声望
创作了5篇指南
徽章: 14
+ 11更多徽章
CPSU-FORTE-W13S17G22
4 名成员
创作了39篇指南
This doesn't explain anything about how to replace the switch
Michael - 2016年8月25日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 5
过去 7 天: 26
过去 30 天: 164
总计 19,999
