本指南有最近更改,您可查看未经巡查的最新版本。
简介
The power switch is located on right side of the Game Boy Advance SP's button panel. It is a grey switch that dictates whether the device is powered on or powered off.
你所需要的
Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
Lift the power switch cover away from the left side of the device using your fingers or tweezers.
17等其他人完成本指南。
