简介
The power switch is located on right side of the Game Boy Advance SP's button panel. It is a grey switch that dictates whether the device is powered on or powered off.
Use a standard Phillips #00 screwdriver to loosen the 4mm screw that keeps the battery cover attached to the device.
Using the tri-wing screwdriver, unscrew the screws holding the back cover to the device. The six screws that need to be removed include:
Four #00 6.45mm tri-wing screws that are located at the corners of the device.
Two #00 4.6mm tri-wing screws that are located at the top-center and bottom-center of the device.
Locate the power switch.
Using your fingers, lift the power switch from the left side of the Game Boy Advance SP.
10等其他人完成本指南。
