跳转到主内容
Nintendo Game Boy Advance SP Buttons Replacement
你所需要的
  1. Nintendo Game Boy Advance SP Buttons Replacement, Battery: 步骤 1 中的图像 1,1
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
    Quel est le nom du vis svp je l'ai perdu et j'ai pas la référence
    la chaîne de Samarium - 回复
    Bonjour @lachainede96340 D'après les instructions du tutoriel, il s'agit d'une vis Phillips (ou cruciforme) #00 de 4 mm de long. Ces mesures devraient suffire pour trouver une vis de remplacement dans votre stock de vis ou en magasin le cas échéant.
    Claire Miesch -
  2. Nintendo Game Boy Advance SP Buttons Replacement: 步骤 2 中的图像 1,1
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Nintendo Game Boy Advance SP Buttons Replacement: 步骤 3 中的图像 1,1
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
  4. Nintendo Game Boy Advance SP Buttons Replacement, Back Cover: 步骤 4 中的图像 1,2 Nintendo Game Boy Advance SP Buttons Replacement, Back Cover: 步骤 4 中的图像 2,2
    • Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
    • Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
  5. Nintendo Game Boy Advance SP Buttons Replacement: 步骤 5 中的图像 1,1
    • Lift the back cover off of the device.
    • Potential for device damage: These inner components are vulnerable to static electricity. Exercise caution when handling these next steps to prevent damaging the device.
    • Look out for the power switch that can fall out when taking the back cover off.
  6. Nintendo Game Boy Advance SP Buttons Replacement, Motherboard: 步骤 6 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the three Phillips #00 4 mm long screws that hold the motherboard to the button panel.
  7. Nintendo Game Boy Advance SP Buttons Replacement: 步骤 7 中的图像 1,1
    • Be careful not to tear the ribbon cable that's connected to the screen. If you tear it, games will not appear on the device's screen!
    • Flip the motherboard up and rest it on the other half of the device, so that the back of the buttons are visible as seen in the picture.
    My Game Boy Advance SP has a problem where it won’t charge the device. The Game Boy is plugged in but the charge light does not go on. How may I turn it back on? What, inside the system, needs to be fixed? Is it one of the cables behind the charging socket inside the Game Boy?
    Connor Hutton - 回复
  8. Nintendo Game Boy Advance SP Buttons Replacement, Removing the Trackpads: 步骤 8 中的图像 1,3 Nintendo Game Boy Advance SP Buttons Replacement, Removing the Trackpads: 步骤 8 中的图像 2,3 Nintendo Game Boy Advance SP Buttons Replacement, Removing the Trackpads: 步骤 8 中的图像 3,3
    • Using your fingers, gently lift and remove the trackpads covering the following:
    • 'A' and 'B' buttons
    • Directional Control Button Pad
    • 'Start' and 'Select' buttons
  9. Nintendo Game Boy Advance SP Buttons Replacement, Buttons: 步骤 9 中的图像 1,3 Nintendo Game Boy Advance SP Buttons Replacement, Buttons: 步骤 9 中的图像 2,3 Nintendo Game Boy Advance SP Buttons Replacement, Buttons: 步骤 9 中的图像 3,3
    • Using tweezers or fingers, lift and remove:
    • Directional control button pad
    • 'Start' and 'select' buttons
结论
12等其他人完成本指南。
团队
Cal Poly, Team 17-22, Forte Winter 2013 Cal Poly, Team 17-22, Forte Winter 2013 的会员
CPSU-FORTE-W13S17G22
4 名成员
创作了39篇指南
5条评论
Hi,
How do I fix my SP Brighter when A and B buttons are simultaneously pressed, the system turns off? Please Help! Thank you in advance!
Jikan - 回复
there is most likely a crack in the mother board or the battery has too much pressure placed onto it
you can fix this by changing the position of the battery and putting something to stop it from moving around so it fits tightly
Taahaco 2005 - 回复
HI there! My problem is that I have to press the button A harder for the action to be registered, how can I fix that?
アラン - 回复
The L and R buttons done work, they go in perfectly fine but would it be the 2 buttons under them that aren't working? If so then how would I remove and replace them safely
Topi2756 - 回复
The buttons L and R don't work, they go in fine so I'm thinking that it's the buttons on the inside that are damaged. If that is the case then how would I remove and replace them safely?
Topi2756 - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 58
过去 30 天: 220
总计 22,182
