当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Use your fingers or a plastic opening tool to remove the battery from the device.
Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
Lift the back cover off of the device.
Potential for device damage: These inner components are vulnerable to static electricity. Exercise caution when handling these next steps to prevent damaging the device.
Look out for the power switch that can fall out when taking the back cover off.
Be careful not to tear the ribbon cable that's connected to the screen. If you tear it, games will not appear on the device's screen!
Flip the motherboard up and rest it on the other half of the device, so that the back of the buttons are visible as seen in the picture.
With your fingers, lift the track pad out off the brightness switch.
Keep the track pad clean. A dirty or dusty track pad will lead to the brightness switch not working when you press it.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
