简介
The brightness switch is the circular button with a sun symbol engraved into it. The brightness switch is located at the top of the button panel.
Use a standard Phillips #00 screwdriver to loosen the 4mm screw that keeps the battery cover attached to the device.
Using the tri-wing screwdriver, unscrew the screws holding the back cover to the device. The six screws that need to be removed include:
Four #00 6.45mm tri-wing screws that are located at the corners of the device.
Two #00 4.6mm tri-wing screws that are located at the top-center and bottom-center of the device.
Using a Phillips #00 screwdriver, remove the three Phillips #00 4 mm long screws that hold the motherboard to the button panel.
8等其他人完成本指南。
